FX-AUDIO D502BT Amplifier FDA TAS5342A Subwoofer Output Bluetooth 5.0 2x60W 4 Ohm Black
FX-AUDIO D502BT Amplifier FDA TAS5342A Subwoofer Output Bluetooth 5.0 2x40W 8 Ohm
The FX-Audio D502BT is, as its name suggests, the successor to the D502. The D502BT takes over its base and components, but this time it comes with a Bluetooth 5.0 receiver, which is very useful for remote music playback from a compatible device such as a smartphone.
4.4 / 5
Reference : 14523
89,00 €tax incl.
74,17 € tax excl.
Shipping from France
Billing in France
Technical support in France
FX-Audio D502BT
FX-Audio D502BT Amplificateur FDA TAS5342A Sortie Subwoofer Bluetooth 5.0 2x40W 8 Ohm
The D502BT is therefore a complete, high-performance FDA (Full Digital Amplifier) amplifier at a contained price. It is equipped with a complete set of connectors, quality components, a beautiful OLED screen and treble / bass settings, while delivering a rich and precise sound.
An efficient TAS5342 amplifier chip
The amplification stage of the D502BT is entrusted to a high-performance TI TAS5342 chip. This one allows to deliver a power of 2x40W under 8 Ohm or 2x60W under 4 Ohm, while ensuring a low noise and distortion rate. A power which will allow you to associate the amplifier with many loudspeakers, especially since the D502BT offers a high efficiency of more than 90%.
In addition, the chip integrates a complete protection system, protecting the device from short circuits, undervoltage, overtemperature or loss of PWM signal.
Bluetooth 5.0
The great novelty of this D502BT version is of course its Bluetooth reception. For this purpose, it embeds a Qualcomm QCC3003 chip, supporting Bluetooth in version 5.0. This allows a fast and stable transmission of audio streams, for high quality listening.
High precision
Cirrus Logic's CS8422 chip is a 24bit asynchronous sample rate converter that also incorporates an S/PDIF interface. The CS8422 allows synchronization with the Master Clock for perfect synchronization and thus ultra-low jitter.
USB SA9023 Interface
To allow you to connect a USB device such as a smartphone for example, the D502BT offers a USB Micro input. Behind this plug is a SA9023 USB interface chip, supporting sample rates up to 24bit 96kHz. A chip that has already proven itself in many audio devices.
NE5532 Subwoofer Output
The NE5532 is an efficient dual operational amplifier. It offers good performance in terms of noise, high gain, low distortion, high scanning speed and numerous protections. In the case of the D502BT, this chip takes care of the subwoofer output.
IR Remote Control
FX-Audio provides an IR remote control with its FDA to control the amplifier and all its functions. No need to get up to turn on the unit, adjust the volume, change sources or adjust bass and treble.
A complete set of connectors
The D502BT, like its predecessor, offers a full range of inputs and outputs to meet the vast majority of needs and allow integration into most audio systems.
1Bluetooth antenna connector
2Micro USB input
3AUX Jack 3.5mm input
4Optical Toslink input
5Coaxial S/PDIF input
6Subwoofer output
7Speaker terminals
8Power supply connector 24V 4A
OLED Screen & Sampling rate display
The front panel of the D502BT features a small, attractive OLED display that shows essential device information such as the current volume level or the active input. On the left side of this screen, a series of LEDs indicate the sampling rate of the file being played.
Product typeFDA Amplifier
Power2x45W @ 8 Ohm
2x60W @ 4 Ohm
InputsBluetooth 5.0
1x AUX Jack 3.5mm
1x Micro USB
1x Optical Toslink
1x Coaxial S/PDIF
Outputs1x Subwoofer output
Speaker terminals
Asynchronous converter chip / SPDIF interfaceCS8422
Amplification chipTI TAS5342A
ADC chipPCM1808
Bluetooth chipQualcomm QCC3003
USB interface chipSA9023
MCU chipSTM8S103F3-32
PWM processorTI TAS5508C
Supported sampling ratesOptiqcal / Coaxial : PCM up to 24bit 192kHz
USB : PCM up to 24bit 96kHz
AUX : PCM up to 24bit 48kHz
Bluetooth : PCM up to 24bit 48kHz
Distortion0.22%
THD+N0.04%
SNR106dB
Subwoofer output level2.7V RMS
Supply voltage24V 4A (power adapter included)
Dimensions132 x 128 x 33mm
Weight525g
Housing materialAluminium
Package1x FX-Audio D502BT
1x IR remote control
1x Power supply
InputJack 3.5mm
OutputSpeaker terminal
OutputSubwoofer
Channel2.1
Amplifier chipTAS5342A
Power (W)40.0
Remote ControlYes
5 reviews
Excellent
Achète pour remplacer l’ampli d’une mini-chaine Denon D-M33, et utilisé pour la TV en optique, le Bluetooth et l’USB (adaptateur Lightning vers USB indispensable sur iPhone). J’en suis très satisfait, rapport qualité prix impressionnant.
This review has been posted for FX-AUDIO D502BT Amplifier FDA TAS5342A Subwoofer Output Bluetooth 5.0 2x60W 4 Ohm Black
Homogéne
Alimente honorablement des enceintes 3 voies de 150 watt ( bc acoustique niger) . Utiliser uniquement en fonction bluethoot , j'ai rajouté des plots anti vibratoire vibrapod 1 ( en vente sur ce site ) qui ont améliorés l'épanouissement et la transparence de la scène sonore . Mérite un rodage avant jugement . Au début l 'aigu était agressif mais je me suis rendu compte que le problème provenait du câble secteur de mon lecteur cd ; preuve de transparence de cet ampli. Le son est équilibré et le suivi mélodique agréable ; écoute non agressive . Je regrette juste un léger manque de dynamique mais ce n'est pas frustrant pour autant . A volume moyen on obtient le meilleur résultat d'écoute mais il faut reconnaitre que vu la taille de l'ampli et le prix pour mes enceintes déjà conséquentes en taille ce n'est pas mal du tout . Content de cet achat .
So far So good
Un rapport qualité prix imbattable pour une installation avec de vieilles 3 voies Kenwood. Branché en usb sur un PC en 96k. RAS après qq heures d'écoute, pas aussi bon que mon vieil ampli Kenwood avec sa paire de Célestion mais encore une fois pour le prix c'est top.
Son excellent
Branché sur mes JBL Control 25 , j'ai redécouvert les aigus et les détails de la musique sur mes HP. Puissance largement suffisante pour le bureau.
la scène sonore est en retrait
- la télécommande est très bien pensée ... voire géniale
-les fonctions sont très bonnes
-l'usb sous Windows 10 est reconnu directement et la musicalité est bien meilleure qu'avec les autres sources
-le son porte loin d'un bon niveau de qualité
-pour le son de la TV... génial!!
-----Avec des enceintes EVA de Davis-----
j'ai utilisé précédemment un Alientek qui est nettement mieux pour la scène sonore
mais fatigant et moins pratique...
...que ce FX-AUDIO tout doux peut-être un peu trop
ce petit ampli qui reste très bien avec Equalizer et Tone pour corriger sérieusement le son sans que cela soit compliqué
Un prix très serré
The FX-Audio D502BT is, as its name suggests, the successor to the D502. The D502BT takes over its base and components, but this time it comes with...
