QULOOS QA690 FDA Power Amplifier 32bit 384khz XMOS 2x100W / 8 Ohm
L'amplificateur Full Digital Amplifier FDA QULOOS QA690 est le digne successeur du QLS QA-100, le premier amplificateur FDA haute qualité abordable du marché.
By buying this product you get 68 loyalty points
Reference : 11366
682,50 €tax excl.
Including 0,04 € for green tax
Quloos QA680
Truly innovative FDA technology:
The Full Digital Amplifier FDA QULOOS QA690 is the worthy successor of the QLS QA-100, the first affordable FDA amplifier on the market that is unanimously acclaimed by its users.
the QULOOS QA690 takes back the electronic quality, the very high level components of the QA100 by bringing innovations which were lacking. Thus, the Quloos brand designer listening to his customers now offers much more than a revision of the QA-100.
The QULOOS QA690 offers all the advantages of FDA amplification with an audio signal reducing all stages of conventional conversion and amplification by only 3 stages instead of the usual 8.
FDA amplifiers, which can be described as digital power converters, offer today a real evolution and alternative to traditional analog and digital amplifiers.
amplificateur FDA Quloos QA680
Very high level active and passive components:
Based around two 150W TAS5624 amplification chips (Texas Instrument), the QA690 offers the ultimate in Full Digital Amplifier.
The asynchronous signal reshaping input chip SRC AKM AK 4137 sends the PCM or DSD audio stream into the amplifier chips with as little jitter as possible.
Inspired by the Quloos QA661 Digital player, the two clocks of the QA690 have their own separate power supplies on LT1763 regulator and ceramic VIMA and NPO film capacitors (thermal stability).
The separate XMOS USB input card features the latest technology from High-End Hi-Fi.
The phase noises (jitter) are thus rejected at the limit of the measurable bringing a liquid, full, analog sound. The design and manufacturing quality of the QA690 far exceeds the usual criteria that have earned the brand its reputation.
The best passive components are in the QA 690 : VIMA, Panasonic capacitors, Vishay MELF and Holco resistors, shielded filter coils at the output.
An analog filter and a high level PSRR power supply:
The power supply with British brand Kemet BHC capacitors (2x10000 µf) is now shielded and separated from the rest of the electronics greatly reducing EMI and RFI pollution between components.
With a significant number of separate LDO low noise controllers (LT1965, LT1963, LM1086) for each voltage, the QA690 offers a stable electrical voltage quality with a high noise rejection rate, necessary for optimal digital signal rendering.
The QULOOS QA680 chassis is made entirely of military grade aluminium on CNC Pirelli machines.
Quloos QA680
JBL 4430 speaker driver by FDA QULOOS
Quloos QA690 review bt Qobuz
" This powerful all-digital amplifier, designed with great seriousness and offering a sound reproduction with a more or less modular clarity according to its tastes, is a choice element to constitute the heart of a quality hi-fi system in a traditional format adapted to the restitution of dematerialized music. "
Test Qobuz
Characteristics:
  • Integrated amplifier FDA 2 amplifier chips TAS5624 2X100 W on 8Ohm
  • High Definition 32bit 384Khz XMOS USB input
  • PurePath Digital Texas Instrument Technology
  • High and low settings
Inputs and outputs:
  • One Asynchronous XMOS USB input: 32 bit 44.1~384Khz and DSD
  • Two 192Khz 24bit SPDIF coaxial inputs
  • One Toslink 24bit 192Khz optical SPDIF input
  • One analog line input on Cinch RCA stereo
  • One stereo speaker output on gold-plated screw terminals
Technical data:
  • Power under 8 Ohm : 2x 100W
  • Power under 4 ohm : 2x160W
  • Dynamic capacity: 101dB
  • Signal-to-noise ratio : 101dB
  • Channel separation: 97dB
  • Distortion : 0.02%
  • Frequency Response: 10 to 20Khz
  • Power consumption in standby mode: 13w
  • Signal ratio, Speaker output: 117dB
Dimensions :
  • 300x216mm x100mm (excluding RCA and volume knob)
  • Weight: 5Kg
Bundle :
  • Remote control with volume control
  • 1m50 USB 3.0 cable
  • 1m50 SPDIF µ-OFC coaxial cable with EMI ferrite
  • IEC mains cable 3 poles
  • Instructions for use in English
Quloos QA680
Quloos QA680
Quloos QA680
Quloos QA680
InputUSB-B
InputUSB XMOS
InputUSB 3.0
OutputSpeaker terminal
Channel2 channels (Stereo)
amplifier chipTAS5624
Power (max)100W
Colissimo - TNT - SoColissimo
5 reviews
la vraie fidelité pour oreilles exigeantes
Oubliez les débats stériles:
En mathématique un signal découpé en une infinité de parties (numériques) permet de retrouver en sortie (a l'entrée du haut parleur) un signal parfaitement analogique et donc plus analogique que l'analogique. Ce qui importe c'est la fidélité et non le transport analogique ou numérique qui poursuivent le même but.
Le débat ne porte plus que sur deux points : la qualité de l'opération (ici composants de 1er ordre) et le faible nombre d'étapes de transformation (moins il y en a moins on altère le signal) d'un bout a l'autre. (ici 3 au lieu d'une dizaine a une vingtaine de circuits électroniques dans un système classique).
Et en bonus vous pouvez écouter les grandes orgues de notre dame à 40hz plein volume avec une alimentation de base qui ne nécessite pas la puissance d'une centrale atomique .
Mais le verdict c'est l'oreille , je pourrais vous dire que c'est inouï, du plus grave au plus aigu en précision et en dynamique et qu'on se croit dans la salle de concert mais curieusement le plus beau compliment pour cet ampli c'est quand dans un film les gens se lèvent pour répondre au téléphone ou ramasser un objet qu'ils ont entendu tomber alors que c'est la bande son du film. C'est dire l'extrême réalisme et la fidélité .
Bien sur sous réserve de bonnes enceintes et de bon enregistrement .
J'ai entendu des systèmes (1 appareil au lieu de 3 ) aussi bons mais a des prix stratospheriques. Celui-là est cher mais c'est relatif!
PS humoristique: même la distortion analogique des amplis de concert du rock des sixties est reproduite a l'identique.
Pour les ordis, ne pas oublier de sortir en USB et paramétrer en wasapi exclusif sinon çà re-échantillonne et vous perdez tout l'interet de cet ampli.
Télécommande fonctionne bien mais un peu cheap.
This review has been posted for QULOOS QA690 FDA Power Amplifier 32bit 384khz XMOS 2x100W / 8 Ohm
Incroyable !
Première fois que je donne un avis ;)
Cet Ampli est tout simplement incroyable.
J’hésitai à passer à un full digital car ayant u quelques amplis AB, je dois le reconnaitre c’est aussi bon !!
Il rivalise sans gène avec des amplis de très haut de gamme.
A consommer sans modération .
Wath else ?
J'ai possédé et je possède encore des amplis qui ont fait la gloire et la notoriété de marques HIFI françaises ou étrangères de haut de gamme. Force est de constater en toute objectivité les qualités exceptionnelles de ce Quloos. N'en déplaise à tous ceux qui s'enorgueillissent d'exposer leurs amplis au prix astronomiques, une écoute en aveugle pourrait leur être fatale ... L'écoute du petit FX 802, avait révélée le potentiel musical des FDA, ce Quloos confirme en allant beaucoup plus loin, l'avenir audio de cette technologie. Une des plus grosses surprises de ma longue passion pour la musique en haute fidélité.
Impressionnant
Associé avec des Boston Accoustics VR2
C'est un monstre de clarté, de puissance et la scène sonore d'en fini plus...
Je découvre des détaille encore jamais entendu sur mes morceaux favoris.
Cette technologie FDA est une belle découverte aucun regret
LA CLAQUE
Après avoir revendu mon ampli HEGEL H160 à 3000 €, encensé par le presse en ayant reçu plusieurs récompenses internationales , mais finalement déçu par l' écoute , j' ai décidé d' acheter ce QULOOS QA 690 avec entrée USB.
En configuration avec un Raspberry 3 ( avec VOLUMIO 2 ) et une carte USB XMOS Audiophonics en sortie SPIDF , là je n' avais jamais entendu un son pareil ! Un son détaillé, chaud , ouvert , pas agressif . Tous les registres sont parfaits. Ouahhh !
Merci à Audiophonics
 (5)
L'amplificateur Full Digital Amplifier FDA QULOOS QA690 est le digne successeur du QLS QA-100, le premier amplificateur FDA haute qualité...
