FURUTECH TF Rhodium Plated OFC Copper Fuse Type T Slow 5x20mm 3.15A
FURUTECH TF Rhodium Plated OFC Copper Fuse Type T Slow 5x20mm 3.1A
Reference : 12234
50,90 €tax incl.
42,42 € tax excl.
Shipping from France
Billing in France
Technical support in France
Fuse Furutech TF Copper OFC plated Rhodium Type T Slow 5x20mm 3.15A
Furutech offers, with its TF range, exceptional semi-slow timed fuses. Indeed, the brand incorporates high-quality components to maximize the performance of the fuse and thus not degrade the quality of the signal passing through it, each step in the signal path being as important as the previous ones or the following ones.
Thus, each material of this fuse is carefully selected and worked. The ends are OFC Copper plated Rhodium with a low-inductance copper alloy conductor and ceramic body with a damping filling. Each metal part is processed by the Alpha process, which consists firstly in cryogenizing the material to consolidate its molecular structure and thus to improve its conductivity and then subjecting it to a strong magnetic field in order to leave no magnetic residue -magnetism).
This is the fuse in 5x20mm 3.1A, sold individually.
TECHNICAL CHARACTERISTICS
  • Current Rating: 3.15A
  • Type T (Slow)
  • Dimensions: 5x20mm
  • Material end: Copper OFC plated Rhodium
  • Conductor Material: Copper Alloy Low Inductance
  • Body Material: Ceramic
  • Treatment: Furutech Alpha
  • Sold individually
Fusible Furutech TF Cuivre OFC plaqué Rhodium 5x20mm 0.25A
caisson basse = résultat basse plus sec
utiliser en remplacement du fusible d'origine d'un caisson basse SANTORIN de chez Cabasse, le son a changé.
C'est devenu physique, la basse est franche, le caisson ne traine plus et bave moins.
Il y a eu une baisse du niveau, j'ai du augmenté le volume mais en retour... (je suis servi)
Moi qui pensais vendre mon caisson je pense attendre encore un peu.
C'est mon retour à moi je ne sais pas si vous obtiendrez le même effet sur un autre caisson mais moi çà me va (utilisation en Homecinema)
This review has been posted for FURUTECH TF Rhodium Plated OFC Copper Fuse Type T Slow 5x20mm 3.15A
