2-way Ceiling Speaker - 6.5" (16.5cm)
With its CS620EC, Dayton Audio offers closed loudspeaker for ceiling mounting, designed to sound large rooms or rooms with blown-in insulation.
The design of this loudspeaker ensures faithful reproduction, whether in the treble or bass, thanks to a Mylar dome tweeter and a cone paper Woofer.
The Dayton Audio CS620EC features a white metal cover that covers the entire speaker. This elegant design makes them almost transparent when mounted on a white ceiling.
Specifications | ||
Speaker application | Ceiling speaker | |
Speaker configuration | 2-way | |
Input rating | 8Ω | |
Power handling | RMS : 25W MAX : 50W | |
Frequency response | 50Hz - 20kHz | |
Sensibivity | 88dB 1W/1m | |
Woofer material | Coated paper | |
Woofer diameter | 6.5"(16.51cm) | |
Tweeter material | Mylar | |
Tweeter size | 1" (2.54cm) | |
Enclosed back | - | |
Color | Blanc | |
Grill material | Métal | |
Total diameter | 11" (27.94cm) | |
Depth | 7" (17.78cm) | |
Mounting hole sizer | 9.56" (24.29cm) |
Speaker Power (W RMS) | 25.0 |
Speaker Type | Ceiling Speaker |
Speaker Type | Midbass |
Impedance (Ω) | 8 |
Loudspeaker diameter (mm) | 165.0 |
Diaphragm type | Mylar |
Diaphragm type | Paper |
Efficiency / Sensitivity (dB) | 88.0 |
Max Linear Excursion (Xmax) (mm) | N/A |
Lowest frequency (Hz) | 50 |
Highest frequency (Hz) | 20000 |
