I build it in a closed box with the recommended box size. The sub cut off is 120 hz in my setup. The bass is good and tight. The metal that holds the wire terminals bends easy. So support it when pushing in the terminals.
This 16.5cm subwoofer speaker has a 36hz cutoff frequency. It allows the design of small subwoofers of quality and affordable. A simple amplifier in class D of 100W RMS RMS or 4 Ohm makes it easy to operate.
The Dayton Classic woofers are designed for 3-way construction as a low medium but can also be used as a subwoofer.
Their versatility allows them to be used both in closed and Bass Reflex
With these impressive performances and these smooth basses, they are popular in many DIY projects.
Characteristics :
Sealed Volume | 5.66 Litres |
Sealed F3 | 80 Hz |
Vented Volume | 14.16 Litres |
Vented F3 | 42 Hz |
Speaker Power (W RMS) | 100.0 |
Speaker Type | Subwoofer |
Impedance (Ω) | 4 |
Loudspeaker diameter (mm) | 165.0 |
Diaphragm type | Kevlar |
Efficiency / Sensitivity (dB) | 87.0 |
Max Linear Excursion (Xmax) (mm) | 6.0 |
Lowest frequency (Hz) | 36 |
Highest frequency (Hz) | 1100 |
Average votes 5.0 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Vincent D.
JEROME P.
