DAYTON AUDIO DCS165-4 6-1/2" Classic Shielded Woofer 4 Ohm Ø 16.5cm
Dayton Audio DCS165-4 6-1/2" Classic Shielded Woofer 4 Ohm Ø 16.5cm
This 16.5cm subwoofer speaker has a 36hz cutoff frequency. It allows the design of small subwoofers of quality and affordable. A simple amplifier in class D of 100W RMS RMS or 4 Ohm makes it easy to operate.
Reference : 10155
49,90 €tax incl.
41,58 € tax excl.
Available
Shipping date: 25-06-2018.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
The Dayton Classic woofers are designed for 3-way construction as a low medium but can also be used as a subwoofer.
Their versatility allows them to be used both in closed and Bass Reflex
With these impressive performances and these smooth basses, they are popular in many DIY projects.
Characteristics :
  • Power: 100W RMS / 200W max
  • Nominal impedance: 4 ohms
  • Resistance DC: 3.4 ohms
  • Frequency response: 36 - 1100 Hz
  • SPL: 87.4 dB 1W / 1m
  • Coil diameter: 38.5mm
  • Nominal diameter: 16.5cm
  • Cutting Diameter: 15cm
  • Mounting depth: 8.5cm
  • 5 years warranty
ColorNoir
BlindageOui
Speaker TypeMidrange
Impédance4
Diamétre Haut Parleur (cm)165
Diaphragm typePaper
StructureMétal
Puissance Totale100 W
Colissimo - TNT - SoColissimo
This 16.5cm subwoofer speaker has a 36hz cutoff frequency. It allows the design of small subwoofers of quality and affordable. A simple amplifier...
