DAYTON AUDIO DCS380-4 Speaker Driver Subwoofer 250W 4 Ohm 94dB 20Hz - 500Hz Ø38.1cm
DAYTON AUDIO DCS380-4 Subwoofer Speaker 4 Ohm Ø38.1cm
This standard Dayton Audio DCS380-4 subwoofer is ideal as a replacement for an HS subwoofer of the same size or for creating a subwoofer.
Strengths:
  • Power handling 250 W on 4 ohm.
  • Resonance frequency 21.5Hz.
  • Ideal for Hifi and home theater use.
Reference : 12499
149,00 €tax incl.
124,17 € tax excl.
Shipping from France
Billing in France
Technical support in France
Subwoofer 4Ω ⌀38.1cm 250W RMS
dayton audio dsc380-4 subwoofer
The DCS380-4 is a standard subwoofer speaker that will be suitable for most systems, replacing an HS subwoofer of the same size or simply for creating a new subwoofer. For maximum versatility, this speaker has been designed to be suitable for both bass reflex and closed speakers. The very robust diaphragm and the large suspensions ensure a high linear excursion for excellent performance in low frequencies.
Speaker typeSubwoofer
Nominal diameter38.1cm (15")
Diaphragm materialPaper cone
Magnet materialFerrite
Voice coil wire materialCopper
Overall outside diameter385mm
Depth186mm
Power handlingRMS : 250W
MAX : 500W
Impedance
Sensitivity93.6dB @ 2.83V/1m
Frequency response20Hz - 500Hz
DC Resistance (Re)2.9Ω
Voice coil inductance (Le)2.31mH @ 1kHz
Resonant frequency (Fs)21.5Hz
Mechanical Q (Qms)3.79
Electromagnetic Q (Qes)0.49
Total Q (Qts)0.44
Diaphragm Mass Inc. Airload (Mms)190g
Mechanical compliance of suspension (Cms)0.29 mm/N
Surface area of cone (Sd)819.4cm²
Volume of displacement (Vd)688.3cm²
Maximum linear excursion (Xmax)8.4mm
Optimum cabinet size according to BassBox 6 Pro
Sealed Volume108.74 Litres
Sealed F340 Hz
Vented Volume361.61 Litres
Vented F321 Hz
This standard Dayton Audio DCS380-4 subwoofer is ideal as a replacement for an HS subwoofer of the same size or for creating a subwoofer....
