DAYTON AUDIO RSS315HF-4 Reference Speaker Driver Subwoofer Aluminium 400W 4 Ohm 90dB 23Hz - 1000Hz Ø 30.5cm
DAYTON AUDIO RSS315HF-4 Reference HP de Grave/Subwoofer 30.5cm
By buying this product you get 20 loyalty points
Reference : 4944
209,00 €tax incl.
174,17 € tax excl.
Available
Shipping date: 19-09-2018.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
DAYTON AUDIO RSS315HF-4 Speaker / Subwoofer Top 30.5cm 4Ω
https://www.audiophonics.fr/images2/DAYTON-AUDIO_LOGO.jpg
Integrated into the "Reference Series"of DAYTON AUDIO, the bass unit RSS315HF-4takes on board the quality and performance criteria that made the success of esteem of the "RS" line of the American manufacturer.
As with all speakers of the reference series, the main objective of this subwoofer is to maintain extremely low distortion ratesdespite a dizzying descent into the serious infra.
Thus the intermodulation distortions of the 2nd and 3rd orders are kept in respect by the use ofthree distinct electrical shortcuts of the engine.
A spider made of Aramid fiber, with exceptional thermal and mechanical resistance, helps to ensure linear and silent excursionof the mobile crew
Notably, the RSS315HF-4also adopts a devastating look with itscone Aluminum color black anodized , herlarge suspension half rubber rollerhigh quality, and sound chassis owner rigid and perfectly ventilated.
"High Fidelity" (HF) version for home audio applications oriented to the accuracy and quality of bass reproduction, with no special constraints on the volume of the load.
https://www.audiophonics.fr/images2/4943_DAYTON-RSS315HF-4_1.jpg
Features:/ Strong>
  • Largely ventilated motor eliminating compression phenomena that are harmful to the linearity and silence of the excursion
  • Very resistant cone Aluminum Anodized Black
  • Three-way electric motor for minimum distortion
  • Double Layer Coiloffering superior protection to EMI
  • Suitable for installation in load close or bass-reflex
  • High quality building materials for increased durability
Specifications:
https://www.audiophonics.fr/images2/4943_DAYTON-RSS315HF-4_2.jpg
https://www.audiophonics.fr/images2/4943_DAYTON-RSS315HF-4_3.jpg
Download DAYTON-RSS315HF-4 DataSheet
Speaker Power (W RMS)400
Speaker TypeSubwoofer
Impédance4
Diamétre Haut Parleur (cm)305
Diaphragm typeAluminium
Rendement86
Xmax14
Lowest frequency23
Highest frequency1000
Colissimo - TNT - SoColissimo
Parfait pour un caisson basse fréquence clos
Monté dans un caisson clos avec filtre DSP et amplification dédier,
La réponse reste parfaitement plate entre 40 et 150Hz +/- 1db
chute à -3db à 33Hz comme prévu dans le calcul et -6dB à 22Hz. Le caisson utilise un résonateur Helmholtz fortement amortis par de la laine, accordé 120Hz avec une bande passante +/- 80Hz . La distorsion est bien contenu dans la plage 33 à 150Hz et remonte légèrement entre 150 et 200Hz la courbe oscillant dans cette dernière plage à +/- 3db.
This review has been posted for DAYTON AUDIO RSS315HF-4 Reference Speaker Driver Subwoofer Aluminium 400W 4 Ohm 90dB 23Hz - 1000Hz Ø 30.5cm
