DAYTON AUDIO RSS390HO-4 Reference Speaker Driver Subwoofer Aluminium 800W 4 Ohm 93dB 21Hz - 600Hz Ø38cm
DAYTON AUDIO RSS390HO-4 Reference HP de Grave/Subwoofer 38cm
By buying this product you get 38 loyalty points
Reference : 4941
385,00 €tax incl.
320,83 € tax excl.
Shipping from France
Billing in France
Technical support in France
Integrated into the "Reference Series"of DAYTON AUDIO, the bass unit RSS390HO-4takes on board the quality and performance criteria that made the success of esteem of the "RS" line of the American manufacturer.
As with all speakers of the reference series, the main objective of this subwoofer is to maintain extremely low distortion ratesdespite a dizzying descent into the serious infra.
Thus the intermodulation distortions of the 2nd and 3rd orders are kept in respect by the use ofthree distinct electrical shortcuts of the engine.
A spider made of Aramid fiber, with exceptional thermal and mechanical resistance, helps to ensure linear and silent excursionof the mobile crew
Small "more" appreciable, the RSS390HO-4adopts a devastating look with itscone Aluminum color black anodized , herlarge suspension half rubber rollerhigh quality, and sound chassis owner rigid and perfectly ventilated.
"HO" version (High Output) specially designed for Audiomobiles applications, or the manufacture of a high powered filtered domestic subwoofer.
https://www.audiophonics.fr/images2/4941_DAYTON-RSS390HO-4_1.jpg
Features:/ Strong>
  • Largely ventilated motor eliminating compression phenomena that are harmful to the linearity and silence of the excursion
  • Very resistant cone Aluminum Anodized Black
  • Three-way electric motor for minimum distortion
  • Quad layer coilfor better power handling
  • Optimized for use in low load volume
  • High quality building materials for increased durability
Datasheets Dayton Audio RSS390HO-4
Dimensions Dayton Audio RSS390HO-4
Optimum cabinet size according to BassBox 6 Pro
Sealed Volume44.74 Litres
Sealed F350 Hz
Vented Volume77.02 Litres
Vented F330 Hz
Speaker Power (W RMS)800.0
Speaker TypeSubwoofer
Impedance (Ω)4
Loudspeaker diameter (mm)380.0
Diaphragm typeAluminium
Efficiency / Sensitivity (dB)93.0
Max Linear Excursion (Xmax) (mm)12.0
Lowest frequency (Hz)21
Highest frequency (Hz)600
