DAYTON AUDIO SPA250 Subwoofer Amplifier plate 250W
Dayton Audio SPA250 Subwoofer Amplifier plate 250W
Reference : 10294
179,00 €tax incl.
149,17 € tax excl.
Available
Shipping date: 25-06-2018.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
The SPA250 is a flat subwoofer with Class AB amplifier that offers the efficiency of a Class D amplifier with state-of-the-art design.
This amplifier uses a circuit which makes it possible to continuously monitor the input signal in order to modulate or regulate the voltage available at the output stage.
Thus, only the necessary power is delivered.
Datasheet Dayton Audio SPA250
Features:/ Strong>
  • Output Power: 156Wrms (8 Ohm), 252 Wrms (4 Ohm) at 0.1% THD
  • Output: 1x RCA, 2x Hp terminal blocks
  • Inputs: 1x RCA (LFE mono), 2x Hp terminal blocks
  • Input Impedance: 10.4K Ohm
  • Signal-to-Noise Ratio (SNR): 90dB Weighted
  • THD: 0.92%
  • Bass Boost function: + 6dB to 35Hz
  • High-pass filter 12dB / oct.
  • Parametric Equalizer: Low Pass 40Hz - 180Hz
  • Volume control: -14.5dB / + 6dB
  • Phase adjustment: 0 ° (NOR) or 180 ° (REV)
  • Frequency response: 30 Hz - 200 Hz
  • Yield: 66%
  • Damping factor: 114 to 100Hz
  • Dimensions: 250x250x13mm
https://www.audiophonics.fr/images2/8895/8895_daytonaudio_SPA500_1.jpg
Channel1 channel (Mono)
ClassClass A / AB
Colissimo - TNT - SoColissimo
Très bon produit
Correspond à la description
Je l'ai installé en nomade et non intégré dans le caisson
This review has been posted for DAYTON AUDIO SPA250 Subwoofer Amplifier plate 250W
