Monte en clos de 90l avec un atohm s500 et un dspeaker c est démoniaque infernal. C est lourd pesant et massif sans etre traînant superbe en home cinéma et bénéfique meme en hifi
The Ultimax range of double coil subwoofers from Dayton Audio is the guarantee of powerful bass. Designed using the latest subwoofer technology, the Ultimax is the ultimate low frequency driver for dynamic, accurate and deep bass.
By buying this product you get 36 loyalty points
Ultimax DVC Subwoofer Speaker 2+2 Ohm Ø38cm
The Double 2 Ohm coils allow the use of 2 Ohm stereo or 1 Ohm mono configurations for high current connection in Car Audio or on professional amplifiers to extract maximum power. For home use, 4 Ohm wiring is preferred for greater compatibility with amplifiers.
To improve power support, thermal management, and reduce compression, Dayton Audio designed the Ultimax range with an anodized structure, open polarized parts, ventilation under the spider, and double layer coils.
The UM15-22 offers a linear excursion (Xmax) of 19mm totally linear thanks to the use of a double spider, also limiting distortion. The rubber suspension with integrated gaskets maintains the diaphragm surface in moments of high travel. Nomex honeycomb diaphragms are covered with high-strength, woven fiberglass that allows the diaphragm to resist deformation.
In the motor, a copper strapping and a copper pole cover also reduce the energy storage of the inductance, with another positive effect of reducing distortion for a faster response. The two very powerful stacked magnets push the Qts (Total Quality Coefficient) to a level that allows the Ultimax to be used in open or closed boxes.
Speaker type | Subwoofer |
Nominal diameter | 38.1cm (15") |
Power handling | RMS : 800W Max : 1600W |
Impedance | 4 Ohm |
Frequency response | 15Hz - 1000Hz |
Sensitivity | 86.5dB 2.83V/1m |
Voice coil diameter | 6.35cm (2.5") |
Measurements | |
Resonant frequency (Fs) | 19.5Hz |
DC Resistance (Re) | 3.4 Ohm |
Voice coil inductance (Le) | 1.31mH |
Mechanical Q (Qms) | 2.40 |
Electromagnetic Q (Qes) | 0.59 |
Total Q (Qts) | 0.47 |
Compliance equivalent volume (Vas) | 7.92ft.³ |
Mechanical compliance of suspension (Cms) | 0.24mm/N |
BL Product (BL) | 15.4Tm |
Diaphragm mass inc. airload (Mms) | 279.4g |
Maximum linear excursion (Xmax) | 19mm |
Surface area of cone (Sd) | 814.6cm² |
Materials | |
Cone amterial | Nomex / Glass fiber |
Surround material | Rubber |
Voice coil wire material | Copper |
Voice coil former | Aluminium |
Basket material | Casr Aluminium |
Magnet material | Ferrite |
Mounting information | |
Overall outside diameter | 38.81cm (15.28") |
Baffle cutout diameter | 35cm (13.78") |
Depth | 19.2cm (7.55") |
Bolt circle diameter | 37.2mm (14.65") |
Mounting holes number | 8 |
Optimum cabinet size (détermined using BassBox 6 Pro) | |
Sealed volume | 3.98ft.³ |
Sealed F3 | 33Hz |
Vented volume | 11.1ft.³ |
Vented F3 | 17Hz |
Sealed Volume | 112.70 Litres |
Sealed F3 | 33 Hz |
Vented Volume | 314.32 Litres |
Vented F3 | 17 Hz |
Speaker Power (W RMS) | 800.0 |
Speaker Type | Subwoofer |
Impedance (Ω) | 4 |
Loudspeaker diameter (mm) | 380.0 |
Diaphragm type | Glass fiber |
Efficiency / Sensitivity (dB) | 87.0 |
Max Linear Excursion (Xmax) (mm) | 19.0 |
Lowest frequency (Hz) | 15 |
Highest frequency (Hz) | 1000 |
Average votes 5.0 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Christophe B.
Christophe B.
