MONACOR SPH-380TC Speaker Driver Woofer 2x250W 4+4 Ohm 89dB 22Hz - 800Hz Ø38cm
MONACOR SPH-380TC Haut-parleur de grave Hi-Fi 38cm
By buying this product you get 41 loyalty points
Reference : 5810
415,00 €tax incl.
345,83 € tax excl.
Shipping from France
Billing in France
Technical support in France
MONACOR SPH-380TC Hi-Fi bass speaker 38cm
Subwoofer speaker with double coil.
40 cm (15 ") model for excellent bass reproduction. Woofer, 2 x 400 W MAX, 2 x 4 Ω
Spider with long travel, aluminum frame, inverted cone diaphragm, long-term rubber peripheral suspension, decompression and core cooling. For universal use in home cinema for example.
Klang + Ton:
"A great HP for universal bass applications, home theater or compact subwoofers."
"The loudspeaker gives the impression of being built for eternity, a superb complement for home cinema and demanding stereo installations."
 https://www.audiophonics.fr/images2/5810/5810_SPH380TC_4.jpg
https://www.audiophonics.fr/images2/5810/5810_SPH380TC_1.jpg
https://www.audiophonics.fr/images2/5810/5810_SPH380TC_3.jpg
https://www.audiophonics.fr/images2/5810/5810_SPH380TC_2.jpg
Speaker Power (W RMS)250.0
Speaker TypeWoofer
Impedance (Ω)4
Loudspeaker diameter (mm)380.0
Diaphragm typeN/A
Efficiency / Sensitivity (dB)89.0
Max Linear Excursion (Xmax) (mm)11.0
Lowest frequency (Hz)22
Highest frequency (Hz)800
