MONACOR SPH-450TC Speaker Driver Woofer 350W 2x4 Ohm 93dB 20Hz - 1500Hz Ø46cm
MONACOR SPH-450TC Haut-parleur de grave Hi-Fi 46cm
By buying this product you get 82 loyalty points
Reference : 5809
829,00 €tax incl.
690,83 € tax excl.
Shipping from France
Billing in France
Technical support in France
Dual coil bass speakers
Incredible low pressure on small speakers.
Decompression and cooling by the core.
Subwoofer, 2 x 500 WMAX, 2 x 4 Ω
Inverted cone diaphragm, gold-plated terminals, molded aluminum chassis, double spider with wide travel. For Hi-Fi, Home-cinema and Hi-Fi applications.
Klang + Ton 01/2010:
'For a real earthquake effect in the Home Cinema! The SPH-450TC is a legend that brings together everything that is classified as serious: diameter 46 cm, 13 mm linear suspension in both directions, breathtaking resonant frequency of 24 Hz. "
Raver Cinema:
"In our home theater room, it recalls all the other subwoofers present."
Hobby HiFi:
"Face to this enormous traveling sound converter, all the bass speakers presented until now in HOBBY HIFI look very pale. "
Features:p align = "center">
https://www.audiophonics.fr/images2/5809/5809_SPH450TC_1.jpg
https://www.audiophonics.fr/images2/5809/5809_SPH450TC_4.jpg
https://www.audiophonics.fr/images2/5809/5809_SPH450TC_3.jpg
https://www.audiophonics.fr/images2/5809/5809_SPH450TC_2.jpg
Speaker Power (W RMS)700.0
Speaker TypeWoofer
Impedance (Ω)4
Loudspeaker diameter (mm)460.0
Diaphragm typeN/A
Efficiency / Sensitivity (dB)93.0
Max Linear Excursion (Xmax) (mm)13.0
Lowest frequency (Hz)20
Highest frequency (Hz)1500
Extraordinaire
Certainement l'un des meilleurs 46 cm au monde pour une utilisation HiFi. Qualité et fiabilité Monacor et un son hallucinant. Je savais ne pas me tromper avec ce modèle. Merci Audiophonics de proposer ce type de HP de haute qualité et de valeur sure.
This review has been posted for MONACOR SPH-450TC Speaker Driver Woofer 350W 2x4 Ohm 93dB 20Hz - 1500Hz Ø46cm
