Polypropylene diaphragm, double coil, parameters allowing a restitution of the bass in compact bass-reflex and band-pass speakers. Uses in Hi-Fi, Home-Cinema, in-car Hi-Fi.
MONACOR SPH-250TC Speaker Driver Woofer 2x100W 2x8 Ohm 91dB Ø25cm
Speaker Power (W RMS) | 60.0 |
Speaker Type | Woofer |
Impedance (Ω) | 8 |
Loudspeaker diameter (mm) | 250.0 |
Diaphragm type | Polypropylene |
Efficiency / Sensitivity (dB) | 91.0 |
Max Linear Excursion (Xmax) (mm) | 4.5 |
Lowest frequency (Hz) | N/A |
Highest frequency (Hz) | 3500 |
