AUNE X7S Headphone Class A amplifier Variable Out Balanced Out Silver
Aune X7S Headphone Class A amplifier Balanced Out.
The pure class A Aune X7S balanced output headphone amplifier is the result of a long research after the nomadic headphone amplifier Aune B1 and the Aune Panda. It is the natural companion of the DAC Aune X1S 32bit 384Khz DSD SABRE ES9018K2M. This headphone amp, completely in class A, is the synthesis of all the know-how of Aune Audio.
Reference : 10954
249,00 €tax incl.
207,50 € tax excl.
Shipping from France
Billing in France
Technical support in France
Aune X7S
Aune X7S Amplificateur Casque Class A Sortie Variable / Symétrique Argent
The pure class A Aune X7S balanced output headphone amplifier is the result of a long research after the nomadic headphone amplifier Aune B1 and the Aune Panda. It is the natural companion of the DAC Aune X1S 32bit 384Khz DSD SABRE ES9018K2M. This headphone amp, completely in class A, is the synthesis of all the know-how of Aune Audio. It is specially designed for high-end high-impact audiophile headphones such as: Sennheiser HD650, IE800, HD800, Beyerdynamic (Tesla) T1, DT880, AKG K701, K240.
Its gain-setting gain setting by "switch" allows a perfect adaptation of impregnation for both low and high impregnation headphones. Its structure is made up of 8 class A polarized transistors divided into 4 groups designed with a true symmetrical layout for cross talk and inaudible, backward background noise. The European sound of the Aune X7S developed by an English team has body, a deep sound image with increased natural musical tracking, a true sound signature of headphone amplifiers in class A. The separate 15 V separate low noise regulated power supply provides the stability necessary for the Aune X7S to operate properly in class A. By its unique design the Aune X7S will be an ideal companion for the digital player made of materialized Aune X5.
Review and measurements by Audio Science Review
The Audio Science Review forum offers a particularly complete test of the Aune X7s with in particular precise measurements of the different parameters of the device.
ClassA
Frequency response20Hz-200kHz @ -0.3dB
Noise level3µV
THD0.00013%
Inter-modulation distotion (CCIF protocol)RCA : 0.000036%
XLR 0.00057%
Output powerRCA : 250mW @ 300 Ohm / 1000mW @ 32 Ohm
XLR : 1000mW @ 300 Ohm / 1700mW @ 32 Ohm
SNRJack 6.35mm : 117dB
XLR : 125dB
Input1x Stereo RCA
Outputs1x Variable stereo RCA
1x Jack 6.35mm
1x XLR 4 polesbalanced
Dimensions145 x 171 x 45mm
Weight2kg
ColorSilver
OutputJack 6.35mm
ColorSilver
Ampli exceptionnel même en asymétrique !
Utilisé en ensemble avec mon Aune X1S.
Je pense que cet ampli n'a pas l'attention qu'il mérite. La scène sonore est large et profonde, l'ensemble du spectre est respecté. Une toute petite pointe de chaleur qui contrebalance bien le côté légèrement brillant de mon X1S en Sabre. Le combo avec le X1S est gagnant sur tout les plans. Puissance, neutralité et transparence, cet ensemble fait pour moi référence avec mon AKG K712 Pro!
Je précise que je n'ai pas utilisé la sortie casque symétriques, qui, d'après les essais va encore plus loin.
Je n'ai à auncun moment eu le besoin d'utiliser le mode High Gain, je n'ose imaginer la puissance en symétrique et en HG, je ne vois aucun casque qu'il ne serai pas capable de driver !
 (3)
This review has been posted for AUNE X7S Headphone Class A amplifier Variable Out Balanced Out Silver
The pure class A Aune X7S balanced output headphone amplifier is the result of a long research after the nomadic headphone amplifier Aune B1 and...
