Heat-shrink tubing 4: 1 Ø04.0mm Black (1m)
Heatshrink tube 4: 1 Ø04.0mm Length 1m (Black)
3.0 / 5
Reference : 4688
1,70 €tax incl.
1,42 € tax excl.
Shipping from France
Billing in France
Technical support in France
Thermo-retractable sleeve with a ratio of 4: 1, internally equipped with an adhesive layer ensuring better maintenance on any type of surface (plastic, rubber, metal ...)
Thickness of intermediate size studied to provide excellent protection to mechanical strength, while maintaining a high degree of flexibility.
Adapts to irregular shapes and provides a high degree of insulation and waterproofing. Product is halogen-free, flame retardant, and RoHS certified.
A ratio of 4: 1 means that the diameter of the sheath once heated will be divided by 4: for example for a 12mm sheath, after being heated its diameter will be 3mm.
Diameter: 4.0mm => about 1mm after retraction
https://www.audiophonics.fr/images2/GAINES-THERMO_1.jpg
Specifications:
  • Retractable Ratio: 4: 1
  • Longitudinal Retracting Ratio: ± 8%
  • Shrink Temperature: 70 - 120 ° C
  • Melting Temperature of Internal Adhesive Layer: 70 - 90 ° C
  • Sheath Thickness After Shrinkage : +/- 1.00mm
  • Temperature Resistance: -45 to + 125 ° C
  • Rigidity Dielectric: ≥15 Kv / mm (IEC243)
  • Certifications: RoHS
  • Diameter: 4.0mm
  • Length: 1m
  • Color Black
Length (m)Sold by length
TRES RAIDE
Je l'imaginait plus fin et souple. mais c'est déjà de la relativement grosse cavalerie, Il y a de la colle thermofusible à l'intérieur. il se rétracte néanmoins très bien, mais avec une épaisseur/raideur assez forte. à réserver pour des câbles d'alim assez gros, avec de la place pour disposer le câblage.
This review has been posted for Heat-shrink tubing 4: 1 Ø04.0mm Black (1m)
