AUDIOPHONICS PSU-HC Linear Power Supply for Auralic Aries Le / Aries Mini 16V 5A 100VA
AUDIOPHONICS Linear Regulated Power Supply 16V 2.5A 60VA
By buying this product you get 26 loyalty points
Reference : 11972
269,00 €tax incl.
224,17 € tax excl.
Shipping date: 25-04-2024.
Shipping from France
Billing in France
Technical support in France
This regulated linear power supply 16V 5A with two jack outputs on 5.5 / 2.1 & 5.5 / 2.5, is dedicated for HiFi audio devices requiring clean and neat power.
It will bring back background noise, a lowering of the "ripple" harmful to the jitter on digital audio devices such as DAC or high fidelity streamers. The result is an improvement of the readability of the acute medium with a less digital sound, a contribution, a seating of the timbre, and a better dynamic bass.
The components of this power supply are of first quality:
  • Metal Resistors
  • 10 capacitors filtering 4700µF
  • Voltage Regulator LT1083
Thus, this regulated linear power supply developed by our team comes to compete with more expensive solutions.
Equipped with a 100% Aluminum case, two Jack DC 5.5 / 2.1 & 5.5 / 2.5, this power supply with an extremely stable 100VA transformer even under heavy load, and will allow you to make the best of connected audio components requesting from 16V up to 5A.
The female DC jack connectors of the PSU-HC require the use of cables with a long male DC jack connector (14.5mm).
Features:
  • Case: 100% Brushed and sanded aluminum
  • Black Anodized
  • Input Voltage: AC 220V
  • Output Voltage / Current: 16V 5A DC
  • 1 output Jack DC 5.5 / 2.1mm
  • 1 DC jack output 5.5 / 2.5mm
  • IEC base with fuse holder
  • Transformer 100VA
Dimensions and weight:
  • 240x170x60mm
  • Weight: 2.4kg
  • Mains cable and DC mains plug not included
InputIEC C14
OutputJack DC 5.5/2.5mm
OutputJack DC 5.5/2.1mm
Output voltage (V)16.0
Output current (A)4.0
Input voltage (V)230.0
Power SupplyLinear
4 reviews
La bonne alim
Après avoir testé toute sorte d'alim plus ou moins au de gamme pour mon auralic femto , c'est celle qui sort du lot. C'est le meilleur compromis entre patate et subtilités d'articulation, c'est pêchu et naturel à la fois. On conserve une bonne profondeur avec de l'air autour des pupitres très posés. On n'est plus dans l'analyse mais dans le plaisir de profiter de la musique.
Si vous êtes dans une configuration avec un dd ou SSD en USB et que vous alimenté une interface USB , c'est la bonne alim.
This review has been posted for AUDIOPHONICS PSU-HC Linear Power Supply for Auralic Aries Le / Aries Mini 16V 5A 100VA
This power supply really improves the sound quality of the Aries mini. Although I only use the digital output of the Aries, the soundstage has improved a lot. The definition of individual instruments, the depth in de stereo image are the most noticeable improvements. There is one minor point of criticism. In my opinion the illumination of the power switch is too bright. It can be easily solved by disconnecting the leads for the light in the power switch. Overall resumé: Can't do without it!
Alimentation linéaire audiophonics
Parfaite pour alimenter un Aries mini. Avec cette alimentation, l’Aries mini est un lecteur reseau de très haut niveau, comparable à des produits beaucoup plus coûteux.
Le top pour utiliser Qobuz.
Apport indéniable
Apporte du poids et du corps aux instruments par rapport à l'alimentation d'origine.
Petit plus que mérite l'aries mini si l'on a un système haute fidélité.
