Cette regulated linear power supply 15V 5A with two jack outputs on 5.5 / 2.1 & 5.5 / 2.5, is dedicated for HiFi audio devices requiring clean and neat power, and MADE IN FRANCE.
It will bring back background noise, a lowering of the "ripple" harmful to the jitter on digital audio devices such as DAC or high fidelity streamers. The result is an improvement of the readability of the acute medium with a less digital sound, a contribution, a seating of the timbre, and a better dynamic bass.
The components of this power supply are of first quality:
- Metal Resistors
- 10 capacitors filtering 4700µF
- Voltage Regulator LT1083
Thus, this regulated linear power supply developed by our team comes to compete with more expensive solutions.
Equipped with a 100% Aluminum case, two Jack DC 5.5 / 2.1 & 5.5 / 2.5, this power supply with an extremely stable 100VA transformer even under heavy load, and will allow you to make the best of connected audio components requesting from 15V up to 5A.
The female DC jack connectors of the PSU-HC require the use of cables with a long male DC jack connector (14.5mm).
Features:
- Case: 100% Brushed and sanded aluminum
- Black Anodized
- Input Voltage: AC 220V
- Output Voltage / Current: 15V 5A DC
- 1 output Jack DC 5.5 / 2.1mm
- 1 DC jack output 5.5 / 2.5mm
- IEC base with fuse holder
- Transformer 100VA
- MADE IN FRANCE
Dimensions and weight:
- 240x170x60mm
- Weight: 2.4kg
- Mains cable and DC mains plug not included
