LPSU200 HiFi Linear Supply High Fidelity 12V + 12V 6.5A 200W NAS / Freebox / Squeezebox
Alimentation stabilisée linéaire 12V + 5V 6.35A 200W NAS/Freebox/Squeezebox.
The Audiophonics team is proud to be able to offer you this dual regulated linear power supply capable of delivering 12V + 12V 6.5A. It is designed to properly power digital players, storage devices and small audio systems. It has two lockable GX16 format (aviation type) outputs delivering a voltage of 12V 6.5A.
4.8 / 5
Reference : 11501
299,00 €tax incl.
249,17 € tax excl.
Shipping from France
Billing in France
Technical support in France
Regulated linear power supply
LPSU200 Alimentation Linéaire Régulée HiFi 12V + 12V 6.5A 200W NAS / Freebox / Squeezebox
The Audiophonics team is proud to be able to offer you this dual regulated linear power supply capable of delivering 12V + 12V 6.5A. It is designed to properly power digital players, storage devices and small audio systems. It has two lockable GX16 format (aviation type) outputs delivering a voltage of 12V 6.5A. GX16 to DC Jack 5.5/2.5mm cables with ferrites are supplied, as well as IEC C13 / Schuko cable. All components are integrated in a robust 100% Aluminium housing.
The power supply is equipped with an effective EMI filter to eliminate unwanted noise. The power supply is specially designed for devices such as:
  • NAS
  • Freebox
  • Mac Mini
  • DAC
  • Squeezebox
  • Docking stations
Product typeRegulated linear power supply
Input voltageAC 220V
Output voltage / current2x 12V DC 13A
Power200W
Input connectorIEC C14
Output connectorsGX16 2 poles (GX16 to Jack DC 5.5/2.5mm cables included)
Dimensions25 x 21 x 9cm
Weight5kg
Housing materialAluminium
ColorBlack, silver front panel
Package1x Regulated linear power supply
2x GX16 2 poles to Jack 5.5/2.5mm cables
1x Power cable 1.4m
InputIEC C14
OutputGX12
ColorSilver
Output voltage (V)12.0
Output current (A)6.5
Input voltage (V)230.0
Power SupplyLinear
9 reviews
indispensable
Peu de temps après la publication de mon avis "problème chauffe", il se trouve qu'un composant de l'alimentation a lâché. Ce sont des choses qui arrivent, Le produit, sous garantie, a été pris en charge par Audiophonics et réparé en moins de temps qu'on peut l'écrire.
Je reviens donc sur cette alimentation, déjà pour à nouveau remercier le SAV et qu'ayant remis, le temps de la réparation, les alimentations à découpage d'origine, je me rends mieux compte du gouffre existant en matière de restitution pour le streaming audio.
Pour ma part, box et NAS branchés dessus.
This review has been posted for LPSU200 HiFi Linear Supply High Fidelity 12V + 12V 6.5A 200W NAS / Freebox / Squeezebox
Problème chauffe
Cette alimentation est excellente. Néanmoins, branchée à ma box et NAS (tous 2 donnés pour du 12V/5A), elle chauffe beaucoup avec un seul appareil branché (box) et le capot devient même brulant avec les 2 appareils connectés. Le SAV Audiophonics m'a aimablement répondu en me disant que c'était normal mais un an après son utilisation, je me demande si elle n'a pas simplement de mal à alimenter les 2 appareils en même temps. Du coup, je me contente de la seule box branchée...
Je recommande
Merci Audiophonics d'avoir réalisé cette alim. J'ai le modèle 12V et 13A et à priori, y en a pas des masses. J'ai également changé les fusibles et le gap est encore énorme. Livraison en temps et en heure, parfait ! On dirait qu'on a à faire à des pros ;-)
exelente.. et a upgrader
bonne alimentation pour un zen lecteur réseaux et la box upc en 12v.. sais un excellent resultat même en qualité video tv.. oublier pas le must. changer la prise iec pour une furutech or ou rhodium.. et les fusible.. la sa fait une grande différence en plus.. le fusible sur l entrée secteur un sr black yc les deux autre fusible a l intérieur.. la il se passe bc de chose.. douceur sérénité et dynamique transitoire nature ..tous monte d un bon cran.. si vous avez moins de 200fr a mettre..3 fusible sr black pas trop cher et une prise furutech or 7 rhodium.. faite le.. la ont a a faire a une alimentation excellentissime.. les câbles fournis sont excellent.. mais la aussi pour pousser plus loin . changer les fils de câblages par des argent mono ou multi brins.. et une prise 5,572.5 elecaudio cuivre tellure or 24k.. mon pote a cette installation.. sa vaut le détour.. pour bricoleurs méticuleux..
Excellent produit pour un nas
Après m'être offert un bon pré-ampli (Atoll Pr300), j'ai constaté une amélioration très qualitative en particulier pour les enregistrements Jazz des années 50_60:qualité des timbres, présence de la contre basse, profondeur de la scène sonore. En revanche, J'avais un écart important de rendu sonore entre la musique écoutée via Qobuz et le même morceau enregistré sur mon NAS.
Fort de ce constat, j'ai branché cette alimentation sur mon Nas et mon routeur.
Le gain en qualité sonore est indéniable. La qualité sonore via mon Nas est montée d'un cran.
Merci à Audiophonics pour cet excellent produit qui plus est pas trop cher par rapport à la concurrence.
The Audiophonics team is proud to be able to offer you this dual regulated linear power supply capable of delivering 12V + 12V 6.5A. It is designed...
