5V 11A 100W DAC / Squeezebox / Docking
The Audiophonics team is proud to present you this regulated linear power supply. It delivers clean power to your digital players, storage devices, and other sensistive audio equipment. It has two GX16 (aviation type) output format with a lockable inlet. Each delivers a voltage of 5V 11A.
Quality components are integrated in a rugged 100% Aluminum for increased robustness and reliability. This power supply is thus among the best value for money in this price range.
The GX16 cable to DC Jack 5.5 / 2.5mm required to use the power supply output is provided.
Positive is located in the center of the DC jack connector.
Type of product | linear regulated power supply |
Input Voltage | AC 220V |
Tensions / output currents | 5V / 11A DC |
Power | 100W |
Output Connectors | GX16 2 poles |
GX16 cable to DC Jack 5.5 / 2.51mm | Provided Postif the center of the DC jack connector |
Dimensions | 257x212x70mm |
Weight | 4.3kg |
Color | Black silver brushed aluminum facade |
Parts supplied | |
GX16 Cable 1.5m 2 pole | x1 |
Power Cable | Not Provided |
Input | IEC C14 |
Output | GX12 |
Color | Silver |
Color | Black |
Output voltage (V) | 5.0 |
Output current (A) | 11.0 |
Input voltage (V) | 230.0 |
Power Supply | Linear |
