Pack AUDIOPHONICS RaspTouch AMP 9023 + Q Acoustics 3010 + OFC HP Cable 2x2m
Pack AUDIOPHONICS RaspTouch Amp 9023 + Q Acoustics 3010 + OFC HP Cable 2x2m
By buying this product you get 59 loyalty points
12103
599,00 €tax incl.
499,17 € tax excl.
Instead of 613,80 €
Pack content
Accessories
PACK RaspTouch Amp 9023 + Q Acoustics 3010 + HP MEDIA-SUN cable
- Amplifier / DAC / Network Reader + Speakers Q Acoustics 3010 Black + Cable HP MEDIA-SUN MS2 2x2m -
Pack Rasptouch amp 9023 + Q Acoustics 3010 + Câble HP
Rasptouch Amp ES9023
The RaspTouch Amp is an all-in-one version of the RaspTouch. Indeed, this network player embodies both an ES9023 DAC supporting sampling rates up to 24bit 192kHz and a TPA3118 Class D amplifier of 2x30W. A coherent set that will enable you to feed yourQ Acoustics speakers with a clean signal for bluffing playback.
In addition, the Rasptouch Amp is a network player using a Raspberry Pi 3, so you can enjoy your music, whether it is stored locally or on a server. In this version it comes with a license of the Max2Play operating system, offering an intuitive and ergonomic interface to navigate within your library and enjoy it without limit.
Q Acoustics 3010 Speakers
The Q Acoustics 3010 loudspeakers provide surprising sound performance and excellent sound reproduction, including a very low resonance of the spectrum.
With very good levels of distortion, the Q Acoustics 3010 prove to be versatile companions who will accompany you during a long listening session or in front of a movie.
The speakers are here in their version Black Graphite, offering a sober and elegant design that will fit perfectly in most interiors.
Speaker cable MEDIA-SUN MS2 Copper OFC 2x2m
These high-quality loudspeaker cables are made of OFC copper conductors to ensure optimum conductivity. They will be able to carry your audio signal efficiently to ensure a good audio output.
TECHNICAL CHARACTERISTICS
Rasptouch Amp 9023
  • DAC: ES9023
  • Amplifier: TPA 3118 (Class D)
  • Power: 2x30W
  • OS: Max2Play
  • Sampling rate: 24bit / 192kHz
  • Entries:
    • 4x USB-A
    • 1x Ethernet RJ45
    • 1x Micro SD Slot
    • 1x HDMI Output
  • Exits :
    • 1x RCA Stereo
  • Display: Capacitive Tactile 7 "
  • Black color
  • Material structure: Aluminum
Q Acoustics 3310
  • Length: 2 x 2m
  • Cabinet type: 2-way reflex
  • Woofer Size: 100mm
  • Heavy-duty motor: 25mm
  • Frequency Response: 68Hz - 22kHz
  • Nominal impedance: 6 Ohms
  • Minimum Impedance: 6 Ohms
  • Sensitivity: 86dB
  • Recommended power: 15 - 75W
  • Transition Frequency: 2.8kHz
  • Dimensions: 235 x 200 x 150mm
  • Weight: 3.6kg per speaker
  • Color: Graphite Black
Media-Sun MS2 cable
  • Length: 2 x 2m
  • Section: 2 x 2.5mm²
  • Insulation: PVC
  • Conductor: Copper - 125 strands 0.15mm (0.02mm²)
  • Cable Thickness: 6.8x3.5mm
  • White Colour
  • Manufacturing
Accepts Banana PlugsYes
OutputRCA Stéréo
Taille Écran7"
Résolution Écran800x400
Colissimo - TNT - SoColissimo
