ATOHM LD130CR04 Speaker Driver Midbass 60W 4 Ohm 88dB Ø13cm
ATOHM LD130 CR04 Medium 13cm (Unit)
Reference : 2252
85,00 €tax incl.
70,83 € tax excl.
Shipping from France
Billing in France
Technical support in France
The LD130CR04 is a midrange bass speaker designed for the realization of a 2-channel system of very high quality in a small footprint.
It is equipped with a paper membrane combined with a peripheral suspension technology LDS ™ characterized by a very specific profile limiting the phenomena of parasitic reflections and standing waves at the mouth of the cone.
The corehas a copper ring which substantially reduces the distortions by third-order harmonic by canceling the creation of induced currents in the pole pieces.
When listened to, these specificities result in an absence of projection phenomenon and a medium register restored with softness and precision.
EIn addition, the low resonant frequency and the high excursion capacity make it possible to obtain a high acoustic pressure in the low frequencies.
You will find in the documents enclosed below the complete technical data sheet.
Speaker Power (W RMS)60.0
Speaker TypeMidbass
Impedance (Ω)4
Loudspeaker diameter (mm)130.0
Diaphragm typePaper
Efficiency / Sensitivity (dB)88.0
Max Linear Excursion (Xmax) (mm)7.0
