ATOHM SD28CR08F Tweeter with silk dome 8 Ohm Ø28mm (Unit)
ATOHM SD28CR08F Tweeter High performance HiFi
2256
109,00 €tax incl.
90,83 € tax excl.
Available
Shipping date: 26-02-2018.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
The SD28CR08F is a high-performance tweeter designed to cover a wide frequency band.
Its 28mm silk treated dome is fixed to an aluminum support reel.
The air gap is ferrofluid in order to increase the permissible power. The core is provided with a copper ring, the advantage of which is to substantially reduce the distortion by harmonic of rank 3.
The rear face of the dome is loaded by a damped cavity to achieve excellent behavior at the lowest frequencies.
The frequency response is characterized by excellent linearity combined with low directivity and an extension of more than 30 kHz.
Thisthe unit will advantageously be combined with the LD 130CR04 or LD 165 CR04 boomer to produce high-end 2-way systems.
Find the complete datasheet in the documents below.
Speaker TypeTweeters à dôme en aluminum
Impédance8 Ohm
Diamétre Haut Parleur (cm)28
MenbraneSoie
Rendement90
Colissimo - TNT - SoColissimo
bjr.j'ai utilisé ce tweeter,car il m'inspirait et bien m'en a pris car il est ecxellent;dans la lignée du D28 dynaudio,avec un filtrage 12 db,linkwitz,a 1,8 khz,il travaille tres bien.je n'aime pas les domes titanes ,ils exagerent en general,lui,il fait bien ce qu'on lui demande;le message est fin ,delicat ,charpenté,propre,avec un bon enregistrement,c'est un regal sur du jazz,les cymbales sont naturelles,comme en vrai,en directe,elles ne font pas ,,,prriiisscchhhhhhhh,voila c'est un bon achat ,n'hesiter pas. PI R
 (4)
This review has been posted for ATOHM SD28CR08F Tweeter with silk dome 8 Ohm Ø28mm (Unit)
