Two-coil subwoofers combine a modern finish with optimized materials. Polypropylene membranes are equipped with a special structure, giving better stability to moisture-insensitive materials.
Hi-Fi Hi-Fi Bass-Surround, 4 Ω, 70 W MAX
High-power bass and midrange, special polypropylene membrane with excellent impulse response, dust cover, lacquered salad bowl with gold-plated connections, 50-4500 Hz; combines ideally with CARPOWER's complementary high-performance speakers. Cutting 144 x 70 mm, external dimensions Ø 165 mm, type 165.
Specifications Speakers | |||
Impedance (Z) | 4 Ω | ||
Resonance frequency (fs) | 65 Hz | ||
Maximum bandwidth | f3-4500 Hz | ||
Maximum power | 70 WMAX | ||
Nominal power (P) | 35 WRMS | ||
Average sound pressure (1 W / 1 m) | 89 dB | ||
Compliance susp. (Cms) | 0.32 mm / N | ||
Movable mass (Mms) | 14.5 g | ||
Mechanical overvoltage. (Qms) | 4.54 | ||
Electrical overvoltage (Qes) | 1.25 | ||
Fact. total overvoltage (Qts) | 0.99 | ||
Volume equ. (VAS) | 11 l | ||
DC resistance. (Re) | 3.6 Ω | ||
Force factor (BxL) | 4.2 | ||
Inductance coil (Le) | 0.6 mH | ||
Coil diameter | 25 mm | ||
Coil support | Alu | ||
Linear Excursion (X MAX) | ± 3 mm | ||
Transmitting surface (Sd) | 137 cm2 | ||
Magnet weight | 10 oz. | ||
Weight | 950 g | ||
