"Free-air" bass speaker SP-167C
Haut-parleur de grave "Free-air" SP-167C
Reference : 1298
18,90 €tax incl.
15,75 € tax excl.
On-board Hi-Fi subwoofers for free air use. Reinforced pressed paper membrane, specific suspension with long travel. With reworked magnetic systems for an even greater power, rear pole plate for an exceptionally large displacement capacity.
150W WooferMAX, 4 Ω
6½ "bass speaker, pressed diaphragm As a complement to" free air "mounting (without housing) in compact vehicles, remodeled product with lower positioning of polarity elements for greater travel.
With the new parameters, which are translated primarily by a greatly improved Qts, these speakers can now be recommended for closed enclosures or even large bass-reflex speakers.
blank.gifImpedance (Z) blank.gif4 Ω
blank.gifBandwidth blank.gif58-5500 Hz
blank.gifResonance frequency (fs) blank.gif49 Hz
blank.gifCut-off frequency (12 dB / oct) (fmax) blank.gif3000 Hz
blank.gifPeak Current blank.gif150 W
blank.gifNominal power blank.gif50 WRMS
blank.gifAverage sound pressure (1 W / 1 m) blank.gif91 dB
blank.gifCms Compliance susp blank.gif0.84 mm / N
blank.gifMms Mobile ground blank.gif12 g
blank.gifQms Mechanical overvoltage. blank.gif2.89
blank.gifElectrical Overvoltage blank.gif0.45
blank.gifQts Fact. total surge blank.gif0.39
blank.gifEquivalent volume (Vas) blank.gif22 l
blank.gifRDC Resistance DC (Re) blank.gif3.7 Ω
blank.gifInductance coil (1 kHz) (Le) blank.gif0.2 mH
blank.gifCoil diameter blank.gif25 mm
blank.gifCoil support blank.gifAlu
blank.gifHeight gap blank.gif4 mm
blank.gifForce factor B x L blank.gif5.6 Tm
blank.gifTransmitting surface (Sd) blank.gif137 cm2
blank.gifMagnet diameter blank.gif100 mm
blank.gifMagnet weight blank.gif20 oz.
blank.gifcutting blank.gifØ 148 mm
blank.gifMounting depth blank.gif80 mm
blank.gifdimensions blank.gifØ 170 mm
blank.gifWeight blank.gif1.15 kg
PDF Download
Colissimo - TNT - SoColissimo
