SP-252C "Free-air" bass speaker
Haut-parleur de grave "Free-air" SP-252C
4.0 / 5
Reference : 1296
52,90 €tax incl.
44,08 € tax excl.
Shipping from France
Billing in France
Technical support in France
On-board Hi-Fi subwoofers for free air use. Reinforced pressed paper membrane, specific suspension with long travel. With reworked magnetic systems for an even greater power, rear pole plate for an exceptionally large displacement capacity.
Bass speaker, 350 WMAX, 4 Ω
25 cm (10 ") bass speaker, pressed diaphragm As a complement to" free air "mounting (without housing) in compact vehicles, remodeled product with lower positioning of polarity elements for greater travel.
With the new parameters, which are translated primarily by a greatly improved Qts, these speakers can now be recommended for closed enclosures or even large bass-reflex speakers.
blank.gifImpedance (Z) blank.gif4 Ω
blank.gifBandwidthblank.gif40-3500 Hz
blank.gifResonance frequency (fs) blank.gif35 Hz
blank.gifCutoff frequency (12 dB / oct) (fmax) blank.gif2000 Hz
blank.gifPeak Current blank.gif350 W
blank.gifNominal powerblank.gif100 WRMS
blank.gifAverage sound pressure (1 W / 1 m)blank.gif93 dB
blank.gifCms Compliance susp.blank.gif0.55 mm / N
blank.gifMms Mobile Maceblank.gif38 g
blank.gifQms Mechanical overvoltage blank.gif3.15
blank.gifQes Overvoltage elec blank.gif0.47
blank.gifQts Fact. total surgeblank.gif0.41
blank.gifEquivalent volume (Vas) blank.gif96 l
blank.gifRDC Resistance DC (Re) blank.gif3.7 Ω
blank.gifInductance coil (1 kHz) (The)blank.gif0.4 mH
blank.gifCoil diameter blank.gif39 mm
blank.gifCoil holderblank.gifATread
blank.gifAir gap heightblank.gif5 mm
blank.gifForce factor B x Lblank.gif8.08 Tm
blank.gifTransmitting surface (Sd) blank.gif353 cm2
blank.gifMagnet diameter blank.gif125 mm
blank.gifMagnet Weightblank.gif30 oz.
blank.gifCutting blank.gifØ 231 mm
blank.gifMounting depthblank.gif110 mm
blank.gifDimensionsblank.gifØ 255 mm
blank.gifWeightblank.gif2.1 kg
Speaker TypeWoofer
bonjour montage de ce sub entre les sièges arrières dans une EOS à l'emplacement de la trappe à ski avec le coffre comme caisson branché sur un JBL Power(1x160w rms) : bon grave rond , impact au bon moment et manque un peu d'infra mais c'était pas vraiment ce que je recherchais pour mon style de musique !!! donc bien satisfait…….
This review has been posted for SP-252C "Free-air" bass speaker
