Two-coil subwoofers combine a modern finish with optimized materials. Polypropylene membranes are equipped with a special structure, giving better stability to moisture-insensitive materials.
Hi-Fi Built-in Hi-Fi Bass Speakers, 4 Ω, 60 W MAX
Grave-medium and powerful bass, special polypropylene membrane with excellent impulse response, lacquered salad bowl with gold-plated connections, 60-5000 Hz; combines ideally with CARPOWER's complementary high-performance speakers. Mounting dimensions 113 x 58 mm, external dimensions 130 x 130 mm, type 130.
Specifications Speakers | |||
Impedance (Z) | 4 Ω | ||
Resonance frequency (fs) | 75 Hz | ||
Maximum bandwidth | f3-5000 Hz | ||
Maximum power | 60 WMAX | ||
Nominal power (P) | 30 WRMS | ||
Average sound pressure (1 W / 1 m) | 88 dB | ||
Compliance susp. (Cms) | 0.30 mm / N | ||
Movable mass (Mms) | 10 g | ||
Mechanical overvoltage. (Qms) | 4.26 | ||
Electrical overvoltage (Qes) | 1.28 | ||
Fact. total overvoltage (Qts) | 0.98 | ||
Volume equ. (VAS) | 5.5 l | ||
DC resistance. (Re) | 3.6 Ω | ||
Force factor (BxL) | 4.0 | ||
Inductance coil (Le) | 0.6 mH | ||
Coil diameter | 25 mm | ||
Coil support | Alu | ||
Linear Excursion (X MAX) | + -2.5 mm | ||
Transmitting surface (Sd) | 92 cm 2 | ||
Magnet weight | 8 oz. | ||
Weight | 750 g | ||
