DAYTON AUDIO CE32A-4 Mini Speaker Full Range 4 Ohm Ø 32mm (Unit)
DAYTON AUDIO CE32A-4 Mini Speaker Full Range 4 Ohm Ø 32mm (Unit) New
This Dayton Audio CE32A-4 mini speaker is designed to meet a variety of needs with a wide frequency response range. It is particularly suitable for small DIY designs
12510
3,50 €tax incl.
2,92 € tax excl.
Mini Speaker 4Ω ⌀32mm
Dayton Audio CE32A-4 Mini haut parleur 4ohm 32mm
With the CE32A-4, Dayton Audio offers a small 4? loudspeaker designed to meet a wide range of needs with a very wide frequency range. It will therefore be suitable for the design of many DIY audio projects, especially for small format loudspeakers.
However, this CE32A-4 loudspeaker offers a high quality design with a concave concave anodized aluminum cone, rubber suspension, fabric spider and neodymium magnet.
Speaker typeMini Speaker
Power handlingRMS : 2W
MAX : 4W
Impedance
Sensitivity78dB @ 1W/1m
Frequency response240Hz - 20kHz
Voice coil diameter12.55mm
DC Resistance(Re)3.57Ω
Voice coil Inductance (Le)0.015mH
Resonant frequency (Fs)268.1Hz/td>
Mechanical Q (Qms)2.86
Electromagnetic Q (Qes)1.24
Total Q (Qts)0.86
Diaphragm Mass Inc. Airload (Mms)0.52Mms
Mechanical compliance of suspension (Cms)0.688 mm/N
Surface Area of Cone (Sd)3.917cm²
BL Product (BL)1.59Tm
Compliance equivalent volume (Vas)0.15l
Maximum linear excursion (Xmax)5mm
Diaphragm materialAluminium
Surround materialRubber
Magnet materialNeodymium
Total diameter32mm
Total depth15.5mm
19mm
Voice coil diameter12.5mm
Dayton audio CE32A-4 mini haut parleur
Speaker TypeLarge bande
Impédance4 Ohm
Diamétre Haut Parleur (cm)320
MenbraneAluminium
Xmax5
Colissimo - TNT - SoColissimo
This Dayton Audio CE32A-4 mini speaker is designed to meet a variety of needs with a wide frequency response range. It is particularly suitable for...
