DAYTON AUDIO CE40-28P-8 Mini loudspeakers 8 Ohm
This small economical replacement eliptical speaker allows a wide range of uses and designs. It provides a surprisingly coherent, intelligible rendering on dialogs for flat screens for example.
Strong points :
  • Lightweight paper loudspeaker cone
  • Powerful and compact magnetic neodymium motor
  • Suspension fabric low resonance
  • Easy mounting with 4 fixing holes
  • Rendering pleasant and intelligible
12297
4,90 €tax incl.
4,08 € tax excl.
Available
Shipping date: 17-01-2018.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
Accessories
DAYTON-AUDIO CE40-28P-8
DAYTON AUDIO loudspeakers CE40-28P
This economical Dayton Audio CE 40-28-P mini speaker features a powerful neodymium motor and a loudspeaker speaker membrane that produces a fast impulse response. Its plastic injected chassis allows a simplified assembly with its 4 fixing holes.
Its wide bandwidth of 15khz to 600hz allows a wide choice of uses as a replacement loudspeaker for TV or flat screen to the design of mini PC speakers to the development of mini line array for public address thanks to its impedance of 8 Ohm.
Features:/ Strong>
  • Nominal diameter: 40 x 28.5mm
  • Power Handling (RMS): 2 Watts
  • Impedance: 8 ohms
  • Frequency response: 550Hz - 15000kHz
  • Sensitivity: 72dB, 2.83V / 1m
  • Coil Diameter: 2.54cm
  • Resonant Frequency (Fs): 607Hz
  • Resistance DC (Re): 7 ohms
  • Coil Inductance (Le): 0.26 mH
  • Q Mechanical QMS: 3.96
  • Q electromagnetic (Qes): 9.87
  • Q total (Qts): 2.83
  • Compliance volume (Vas): 0.0005 liter
  • Coil diameter: 1.27 mm
  • Mechanical suspension compliance (Cms): 0.177 mm / N
  • BL Product (BL): 1.3 Tm
  • Supported by the diaphragm (Mms): 0.37g
  • Maximum linear excursion (Xmax): 0.1mm
  • Surface area of ​​the cone (Sd): 5.28cm²
Building materials:
  • Cone: Treated paper
  • Suspended material: Non-resonant fabric
  • Neodymium Magnet
  • Reinforced plastic injected frame
Mounting information:
  • Overall external dimension: 40 x 28.5 mm
  • External Depth: 11mm
  • Mounting holes: 4
  • Weight: 22g
Dayton audio CE40-28-P
Speaker TypeLarge bande
Impédance8 Ohm
Diamétre Haut Parleur (cm)48x28 mm
MenbranePapier
Rendement72
Xmax4.6
Colissimo - TNT - SoColissimo
This small economical replacement eliptical speaker allows a wide range of uses and designs. It provides a surprisingly coherent, intelligible...
