DAYTON AUDIO DAEX32EP-4 Thruster Speaker Exciter Ø 32mm 4 Ohm
Haut parleur Thruster 40 4 Ohm 400XW
Among the most advanced and precise vibrating speakers from DAYTON Audio with a generous 32mm diameter motor. An original speaker model that is reminiscent of an audio construction game from the point of view of the innumerable possibilities and applications that these devices can have.
Reference : 12637
23,90 €tax incl.
19,92 € tax excl.
Shipping date: 29-03-2024.
Shipping from France
Billing in France
Technical support in France
DAEX32EP - Discreet and practical speaker
Speaker excite DAEX32EP-4 Dayton Audio
Like any speaker exciter, the DAEX32EP-4 is designed to be positioned on a flat surface and / or hollowed to be used as a sounding board. It may vibrate any object at high frequencies to produce sound (the support replaces the speaker cone).
One can find a lot of more or less curious applications to these sources, the most traditional being in the home theater to add vibrations perceptible to the touch & phonetically in the sensory environment of the viewer. It's also a fun option to carry around as it is a compact and modular speaker with nice space-usage/power ratio, when the imperative of audio precision is not a top priority.
A robust and ergonomic design for easy installation
Speaker audio exciter Dayton
The DAEX32EP-4 sees a significant manufacturing quality with its steel structure and its 32 mm in diameter motor. This generous first design ensure excellent vibration transmission, but also increase the strength of the top speaker.
The device has already pre-installed on its surface a self-adhesive tape. As a sticker, simply remove the cover and install your speakers and do not waste time.
Compact solution
Side view of the speaker buzzer audio dayton
Its impedance of 4 ohms 4-DAEX32EP make a choice of the candidate to work with Class D amplifiers of modest size. Thus it will be possible to enjoy a very original, compact and enjoying a hard to match supply facilities performance.
Used in several copies, it is even possible to create a stereo effect or get impressive volume based on the relevance of positioning (facts in the download tab of this product).
Impedance4
Resistance (Re)3.3
Inductance @ 1kHz (The)0.21
Resonant Frequency (without space)395
Total quality1.38
Mass movement load + air5.4
Compliance of the suspension0.08
Engine power (BL)4.2
Diameter of the surface32 mm
Weight148g
RMS power40W
Frequency rangedepends on the surface
Blade connector2.8mm
Speaker Power (W RMS)40.0
Speaker TypeExciter
Impedance (Ω)4
Loudspeaker diameter (mm)32.0
Diaphragm typeN/A
Max Linear Excursion (Xmax) (mm)N/A
Lowest frequency (Hz)N/A
Highest frequency (Hz)N/A
2 reviews
super pour sonorisation on ceiling
Hello Je rejoins Jean B. ce sont de super exciter pour réaliser des DML J'ai réalisé la sonorisation d'une pièce de 35M2 avec 4 panneaux DML de 50x100cm construits en multiplis aviation de 3.5mm d'épaisseur 5 plis en bouleau. j'ai réalisé des renforts de type table d'harmonie. ils sont suspendus au plafond. Je les coupe à 200Hz. plus bas c'est compliqué de maitriser les résonances. et de tout façon la taille des panneaux ne le permet pas. La coupure acoustique du DML est à 180Hz. Je les ai associé à un petit caisson maison j'ai utilisé des ampli Wondom afin de bénéficier du DSP pour corriger les effets liés à la pièce ainsi que la proximité du plafond derrière les panneaux. effet ambiphonique garantie.
This review has been posted for DAYTON AUDIO DAEX32EP-4 Speaker Driver Exciter Bodyshaker Full Range 40W 4 Ohm Ø3.2cm
DML
Parfait pour de petits panneaux DML.
Conseil perso, faites des panneaux légers, de faible épaisseurs et très rigides, n'hésitez pas mélanger les matériaux. Et de les utiliser avec des amplis avec contre-réaction en courant, y compris de petits LM1875.
Résultats étonnant pour le prix et l'encombrement.
Jean
Among the most advanced and precise vibrating speakers from DAYTON Audio with a generous 32mm diameter motor. An original speaker model that is...
