DAYTON AUDIO DC130BS-4 Classic Speaker Driver Midbass Shielded 30W 4 Ohm 92dB 55Hz - 4000Hz Ø14cm
Dayton Audio DC130BS-4 5-1/2" Classic Shielded Woofer Ø 14cm
Dayton Classic woofers are designed for 3-way construction as low-midrange speakers, but can also be used as subwoofers. Their versatility means they can be used in both closed and bass reflex applications. With their impressive performance and smooth bass, they are popular in many DIY projects.
4.0 / 5
Reference : 11078
32,90 €tax incl.
27,42 € tax excl.
Shipping date: 02-04-2024.
Shipping from France
Billing in France
Technical support in France
Features :
Power handling (RMS) 30 watts.
Maximum power 60 watts.
Impedance 4 ohms.
Sensitivity 91.6 dB @ 2.83V/1m.
Frequency response: 55 - 4,000 Hz.
Coil diameter 25 mm.
DC resistance (Re) 3.55 ohms.
Coil inductance (Le) 0.5 mH @ 1 kHz.
Resonance frequency: (Fs) 51.8 Hz.
Qms : 1.86.
Qes : 0.44.
Qts : 0.35.
Diaphragm mass (Mms) 8.8g.
Suspension mechanical compliance (Cms) 1.08 mm/N.
Cone surface area (Sd) 93.3 cm².
Volume displaced: (Vd) 14.0 cm³.
BL 4.8 Tm.
Vas: 13.2 liters.
Maximum linear excursion (Xmax) 2.5 mm.
Paper cone.
Rubber suspension.
Aluminium wire coil.
Aluminum coil support.
Ferrite magnet.
Shielded magnet.
Overall diameter: 145 mm.
Hole diameter: 120 mm
4 mounting holes.
Speaker weight: 910 gr.
Speaker Power (W RMS)30
Speaker TypeMidbass
Impedance (Ω)4
Loudspeaker diameter (mm)140.0
Diaphragm typePaper
Efficiency / Sensitivity (dB)92.0
Max Linear Excursion (Xmax) (mm)2.5
Lowest frequency (Hz)55
Highest frequency (Hz)4000
Fait bien le taf :)
Pour une petite biblio à pas cher, fait très bien l'affaire. La distorsion remonte malheureusement assez facilement dès 1500hz, mais une coupure franche type LR4 peut maitriser ça.
Son petit diamètre est parfait pour une directivité propre et un raccord autour de 2kHz.
L'extension dans les basses n'est pas folle, mais en surlitrant ou en baissant la Fs de l'event, on obtient une jolie courbe "façon clos" qui va très bien une fois posé sur une étagère proche du mur arrière.
Un bon soldat selon moi ! Voir le projet tritix MT (anglophone)
This review has been posted for DAYTON AUDIO DC130BS-4 Classic Speaker Driver Midbass Shielded 30W 4 Ohm 92dB 55Hz - 4000Hz Ø14cm
Dayton Classic woofers are designed for 3-way construction as low-midrange speakers, but can also be used as subwoofers. Their versatility means...
