DAYTON AUDIO DC200-8 Classic Speaker Medium Grave 8 Ohm Ø20.3 cm (unit)
DAYTON AUDIO DC200-8 Haut-Parleur Woofer 8 Ohm Ø20.3 cm (unité)
The DC200-8 8 Inch Speaker from Dayton Audio offers a great value for money in its range. It is designed to offer high performance while remaining very accessible.
4.7 / 5
Reference : 12627
42,90 €tax incl.
35,75 € tax excl.
Shipping from France
Billing in France
Technical support in France
DC200-8 Classic 8-inch woofer - low frequencies with well-defined contours
The DC200-8 8 Inch Speaker from Dayton Audio offers a great value for money in its range. It is designed to offer high performance while remaining very affordable. Its classic and efficient construction incorporates a non-pressed treated paper cone, a voice coil ASV, a ventilated motor structure (vented woofer) and a rubber surround for a good rendering of low frequencies.
Ideal for building a speaker or improving an existing device
The DC200-8 Speaker will fit a variety of uses. It is especially effective for repairing or upgrading an existing device. Its dimensions make it an ideal candidate to upgrade or replace the speaker of some popular models, such as Bose 301, Pionner CS-33a or even Advent Heritage.
Those who are most interested in the speaker construction part will be pleasantly surprised by the responsive response of low frequencies. A round sound with a beautiful presence that will ideally complement a medium-sized installation (living room / bedroom). Above average performance at the right price makes Dayton Audio's DC200-8 loudspeaker an obvious choice for fast and efficient construction.
Speaker TypeWoofer
PowerRMS : 60 Watts
Max : 120 Watts
Impedance8 Ohm
DimensionsØ205 mm  x 93.5 mm
Weight3.5 lbs
Frequency response29 - 3000 Hz
Sensibility87 dB 2.83V/1m
Coil Diameter3.5 cm
Resonance Frequency30.3 Hz
Nominal Diameter8 Pouces / 20.3 cm
Resistance DC (Re)6.41 Ohm
Coil Inductance (Le)2.32 mH
Electromagnetic Q (Qes)0.49
Mecanical Q (Qms)3.06
Total Q (Qts)0.42
Diaphragm Mass Inc. Airload (Mms)36.1g
Mechanical Compliance of Suspension (Cms)0.77 mm/N
Surface Area Of Cone (Sd) 211.2 cm²
Maximum Linear Excursion (Xmax)4.5 mm
Speaker Power (W RMS)60.0
Speaker TypeWoofer
Impedance (Ω)8
Loudspeaker diameter (mm)205.0
Diaphragm typePaper
Efficiency / Sensitivity (dB)87.0
Max Linear Excursion (Xmax) (mm)4.5
Lowest frequency (Hz)29
Highest frequency (Hz)3000
3 reviews
Réfection
Excellent HP pour remplacement de caisson de basse
This review has been posted for DAYTON AUDIO DC200-8 Classic Speaker Driver Woofer 60W 8 Ohm 87dB 29Hz - 3000Hz Ø20.5cm
Bon rapport qualité prix
Utilisé en complement des produits HP dayton PC105 & DC28 et d'un filtre monacor 3 voie, j'ai refait pour 200 euros mes enceintes Jamo studio 170 de 25 ans qui étaient devenues "plates" et donc l'écoute été fatigantes à la longue. Un peu de de laine, une charge close et de l'huile de coude. Le poid des enceintes à doubler et la qualité du son aussi : précis et dynamique. Parfait pour les budgets restreints.
Bose 301 s 1
En attendant une réparation à l'originale actuellement en rodage avec un mistral lfd déjà très bien ! Pas livraison super rapide merci!
The DC200-8 8 Inch Speaker from Dayton Audio offers a great value for money in its range. It is designed to offer high performance while remaining...
