DAYTON AUDIO DC28FT-8 Speaker Driver Dome Tweeter Silk 50W 8 Ohm 89dB 1300Hz - 20kHz Ø2.8cm
DAYTON AUDIO DC28FT-8 1-1/8 dome silk tweeter 28mm
This 28mm silk dome tweeter is strongly inspired by the prestigious Nordic solutions and provides a silky, pleasant sound and high capacity for detail. With a straight-line linear frequency response, slightly downward, it is easily integrated into any configuration close to the bass midrange thanks to its chassis with straight cut edges, optimizing the coherence of the sound reproduction.
4.8 / 5
Reference : 11540
28,90 €tax incl.
24,08 € tax excl.
Shipping date: 25-04-2024.
Shipping from France
Billing in France
Technical support in France
Inspired by the designs and designs of European tweeters, the Dayton Audio DC28FT-8 1-1 / 8 is often compared to Danish and Norwegian references with much more expensive 28mm silk domes. It takes the same technologies from these competitors at a fraction of their prices.
Technical advantages:
  • Internal rear chamber for low connection frequency (834hz)
  • Tweeter with silk dome 28mm for a better compromise power and directivity
  • Powerful 74mm magnetic motor
  • The fabric dome allows a silky, soft and always pleasant sound
  • Large gold-plated contacts terminals compatible with lugs
His dome silk and hispowerful magnetic motormake it an excellent competitor unassailable in this price range. Its truncated face allows an integration closer to the low medium in order to reinforce the sound cohesion. It will be ideal for use MTM (medium, tweeter, medium) of Appolito type for example.
Features:
  • Tweeter type Soft silk dome
  • Diameter 28mm
  • Impedance 8 ohms
  • Power Consumption: 50 Watts (RMS)
  • Bandwidth: 1,300 to 20,000 Hz
  • Sensitivity: 89 dB 1W / 1m
Specifications:
  • Re: 5.5 ohms
  • On: 0.09 mH @ 10khz
  • Fs: 834Hz
  • Qms: 0.81
  • Qes: 1.33
  • Qts: 0.5
  • Coil: 29mm
  • SPL: 89 dB @ 1W / 1M
  • Acceptable Power: 50W RMS
dayton Audio tweeter en soie 28mm
dayton Audio tweeter en soie 28mm D28
Speaker Power (W RMS)50.0
Speaker TypeDome tweeter
Impedance (Ω)8
Loudspeaker diameter (mm)28.0
Diaphragm typeFabric
Efficiency / Sensitivity (dB)89.0
Max Linear Excursion (Xmax) (mm)N/A
Lowest frequency (Hz)1300
Highest frequency (Hz)20000
4 reviews
Surprenant tweeter
Je l'ai commandé en me basant sur sa bonne réputation. Il l'a mérite cette réputation. Très très sympa, de la présence, un son très agréable. Je suis même surpris de sa sensibilité qui me paraît faible en rapport à sa présence. Je l'ai coupé à 12db assez haut (5000hz) j'en suis enchanté.
This review has been posted for DAYTON AUDIO DC28FT-8 Speaker Driver Dome Tweeter Silk 50W 8 Ohm 89dB 1300Hz - 20kHz Ø2.8cm
Very good cheap tweeter
Good tweeter for the money. The tweeter sounds nice and clear. 4 stars because the tweeter membrane is covered in some sticky stuff which dust will stick to. A dust cover is a must for this tweeter!
Gasp
Excellent rapport qualité, prix vaut largement des tweeters bien plus chers
DAYTON AUDIO DC28FT-8 Haut-Parleur Tweeter à Dôme Soie 50W 8 Ohm 89dB 1300Hz - 20kHz Ø 2.8cm DAYTON AUDIO DC28FT-8 Haut-Parleur Tweeter à Dôme Soie 50W 8 Ohm 89dB 1300Hz...
Superbe tweeter en remplacement d'un TW 20 sur des enceintes B W DM5. Excellent résultat avec le changement du câblage interne ( Néotech
cuivre OCC ) + bornier de qualité ( fréquence de coupure du filtre à 2500 Hz). Les enceintes sont alimentées par un FDA Alientek D8 sous PC windows avec Foobar + Asio : aigu raffiné et étendu . Très recommandable, avec un excellent RPQ. Merci Audiophonics.
This 28mm silk dome tweeter is strongly inspired by the prestigious Nordic solutions and provides a silky, pleasant sound and high capacity for...
