DAYTON AUDIO DCS305-4 Speaker Driver Subwoofer 250W 4 Ohm 90dB 23Hz - 200Hz Ø30.5cm
DAYTON AUDIO DCS305-4 Subwoofer Speaker 4 Ohm Ø30.5cm
This standard Dayton Audio DCS305-4 subwoofer is ideal as a replacement for an HS subwoofer of the same size or for creating a subwoofer.
Strengths:
  • Power handling capacity: 250w out of 4 Ohm
  • Resonance frequency: 24.5Hz
  • Suitable for Hifi and Home Cinema use
Reference : 12500
139,00 €tax incl.
115,83 € tax excl.
Shipping date: 25-04-2024.
Shipping from France
Billing in France
Technical support in France
Subwoofer 4Ω ⌀30.5cm 250W RMS
dayton audio dsc305-4 subwoofer
The DCS305-4 is a standard subwoofer speaker that will be suitable for most systems, replacing an HS subwoofer of the same size or simply for creating a new subwoofer. For maximum versatility, this speaker has been designed to be suitable for both open and closed speakers. The very robust diaphragm and the large suspensions ensure a high linear excursion for excellent performance in low frequencies.
Speaker typeSubwoofer
Nominal diameter30.48cm (12")
Diaphragm materialPaper / Kevlar
Magnet materialFerrite
Voice coil wire materialCopper
Overall outside diameter306mm
Depth153mm
Power handlingRMS : 250W
MAX : 500W
Impedance
Sensitivity90.5dB @ 2.83VW/1m
Frequency response23Hz - 200Hz
DC Resistance (Re)3.3Ω
Voice coil inductance (Le)2.06mH @ 1kHz
Resonant frequency (Fs)24.2Hz
Mechanical Q (Qms)5.07
Electromagnetic Q (Qes)0.43
Total Q (Qts)0.40
Diaphragm Mass Inc. Airload (Mms)160g
Mechanical compliance of suspension (Cms)0.27 mm/N
Surface area of cone (Sd)498.8cm²
Volume of displacement (Vd)468.8cm²
Maximum linear excursion (Xmax)9.3mm
Optimum cabinet size according to BassBox 6 Pro
Sealed Volume32.28 Litres
Sealed F348 Hz
Vented Volume96.84 Litres
Vented F326 Hz
Speaker Power (W RMS)250.0
Speaker TypeSubwoofer
Impedance (Ω)4
Loudspeaker diameter (mm)305.0
Diaphragm typeKevlar
Diaphragm typeCarbon kevlar
Efficiency / Sensitivity (dB)90.0
Max Linear Excursion (Xmax) (mm)8.4
Lowest frequency (Hz)23
Highest frequency (Hz)200
This standard Dayton Audio DCS305-4 subwoofer is ideal as a replacement for an HS subwoofer of the same size or for creating a subwoofer....
