DAYTON AUDIO DCS380-4 Subwoofer Speaker 4 Ohm Ø38.1cm (Unit)
DAYTON AUDIO DCS380-4 Subwoofer Speaker 4 Ohm Ø38.1cm New
This standard Dayton Audio DCS380-4 subwoofer is ideal as a replacement for an HS subwoofer of the same size or for creating a subwoofer.
Strengths:
  • Power handling 250 W on 4 ohm.
  • Resonance frequency 21.5Hz.
  • Ideal for Hifi and home theater use.
12499
109,00 €tax incl.
90,83 € tax excl.
Available
Shipping date: 18-01-2018.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
Subwoofer 4Ω ⌀38.1cm 250W RMS
dayton audio dsc380-4 subwoofer
The DCS380-4 is a standard subwoofer speaker that will be suitable for most systems, replacing an HS subwoofer of the same size or simply for creating a new subwoofer. For maximum versatility, this speaker has been designed to be suitable for both bass reflex and closed speakers. The very robust diaphragm and the large suspensions ensure a high linear excursion for excellent performance in low frequencies.
Speaker typeSubwoofer
Nominal diameter38.1cm (15")
Diaphragm materialPaper cone
Magnet materialFerrite
Voice coil wire materialCopper
Overall outside diameter385mm
Depth186mm
Power handlingRMS : 250W
MAX : 500W
Impedance
Sensitivity93.6dB @ 2.83V/1m
Frequency response20Hz - 500Hz
DC Resistance (Re)2.9Ω
Voice coil inductance (Le)2.31mH @ 1kHz
Resonant frequency (Fs)21.5Hz
Mechanical Q (Qms)3.79
Electromagnetic Q (Qes)0.49
Total Q (Qts)0.44
Diaphragm Mass Inc. Airload (Mms)190g
Mechanical compliance of suspension (Cms)0.29 mm/N
Surface area of cone (Sd)819.4cm²
Volume of displacement (Vd)688.3cm²
Maximum linear excursion (Xmax)8.4mm
Speaker TypeSubwoofer
Impédance4 Ohm
Diamétre Haut Parleur (cm)380
MenbranePapier
Puissance Totale250-300 Watts
Puissance Totale200-250 Watts
Colissimo - TNT - SoColissimo
This standard Dayton Audio DCS380-4 subwoofer is ideal as a replacement for an HS subwoofer of the same size or for creating a subwoofer....
