DAYTON AUDIO PK165-8 Professionnal Speaker Medium 8 Ohm 15.2 cm
PC105-8 4" Full-Range Poly Cone Driver
Can be used as a main driver in a compact sound system or as a midrange / bass speaker in a more complex installation.
Reference : 12629
46,90 €tax incl.
39,08 € tax excl.
Shipping from France
Billing in France
Technical support in France
Medium speaker PK165-8
Driver PK165-8 Dayton Audio
The PK165-8 Dayton Audio speaker delivers midrange frequencies with low distortion and good sensitivity in this range. This speaker can be used as a main audio source in a compact sound system as well as a midrange / bass speaker in a more complex installation. Its frequency band extends in the low frequencies up to 95 Hz with a sufficient reactivity to enrich the listening in a significant way.
From the point of view of the sounds, this model provides a clear and neutral sound that will leave intact the nuances of the sound and the subtleties of the amplifier. The PK165-8 is a relatively demanding speaker in terms of power that will give very convincing results in medium and high powers. Used with a decent amplifier, it will provide a very satisfying result in a high-fidelity installation.
A strong and efficient design
side view of PK165-8
Built in a steel structure, the PK165-8 features a Kevlar reinforced paper cone, an acoustic treatment cloth, a ventilated pole piece and an aluminum coil wound on a polyimide former. An efficient manufacturing process makes this speaker a practical and affordable solution for a wide range of needs.
Speaker typeMedium
PowerRMS : 100 Watts
Max : 200 Watts
Impedance8 Ohm
DimensionsØ165 mm  x 75.2 mm
Frequency Response95 - 9000 Hz
Sensitivity91.4 dB @ 2.83V/1m
Voice Coil Diameter3.8 cm
Resonnant Frequency (Fs)91.5 Hz
Nominal Diameter8 Pouces / 20.3 cm
DC Resistance (Re)6.8 Ohm
Voice Coil Inductance (Le)0.81 mH
Electromagnetic Q (Qes)0.77
Mechanical Q (Qms)7.93
Total Q (Qts)0.7
Diaphragm Mass Including Airload (Mms)10g
Mechanical Complicance of Suspension (Cms)0.3 mm/N
Surface Area of Cone (Sd) 113.1 cm²
Maximum Linear Excursion (Xmax)1.5 mm
Speaker Power (W RMS)100.0
Speaker TypeMidrange
Impedance (Ω)8
Loudspeaker diameter (mm)152.0
Diaphragm typeCarbon kevlar
Diaphragm typeKevlar
Efficiency / Sensitivity (dB)91.0
Max Linear Excursion (Xmax) (mm)1.5
Lowest frequency (Hz)95
Highest frequency (Hz)9000
DAYTON AUDIO PK165-8 Speaker Driver Midrange Kevlar / Paper 100W 8 Ohm 91dB 95Hz - 9000Hz Ø16.5cm
