DAYTON AUDIO PS95-8 Full range Speaker 8 Ohm Ø9cm
Dayton Audio PS95-8 Haut Parleur 9cm
9309
17,90 €tax incl.
14,92 € tax excl.
Dayton Audio PS95-8 Broadband Speaker 9cm
The PS95-8 is a loudspeaker that has the distinctive feature of producing both bass, articulated and balanced midrange, as well as extended treble.
The loudspeakers of this range are thus able to represent a high sensitivity and a gentle response.
SP95-8 Dayton Audio Documentation
Specifications:
  • Nominal Power (RMS): 10 Watts
  • Nominal Power (Max): 20 Watts
  • Impedance: 8 ohms
  • Frequency response: 100 to 20,000 Hz.
  • Sensitivity: 83dB 2.83V / 1m
  • Coil diameter: 20mm
  • Resonant Frequency (Fs): 115Hz
  • Resistance DC (Re): 7.26 Ohms
  • Inductance Voice Coil (Le): 0.61 mH
  • Q Mechanical (QMS): 8.40
  • Q electromagnetic (Qes): 0.83
  • Q total (Qts): 0.76
  • Equivalent volume of conformity (Vas): 0,91m³
  • Mechanical suspension compliance (Cms): 0,81mm / N
  • BL Product (BL): 3.83 Tm
  • Diaphragm Mass Inc. Airload (MMS): 2.33g
  • Max. Linear travel (Xmax): 2.5mm
  • Surface of cone (Sd): 28,3cm²
  • Cone Material: Paper / Kevlar
  • Coil: Aluminum
  • Overall Outside Diameter: 76.8mm
  • dicutting aperture: 69.8mm
  • External Depth: 52.3mm
  DAYTON PS95-8
DAYTON PS95-8
DAYTON PS95-8
Speaker TypeLarge bande
Impédance8 Ohm
Diamétre Haut Parleur (cm)90
MenbranePapier
Rendement83
Xmax2
Colissimo - TNT - SoColissimo
