DAYTON AUDIO PT2C-8 Speaker Driver Ribbon Tweeter 80W 8 Ohm 94dB 2000Hz - 26kHz 120mm
DAYTON AUDIO PT2C-8 Ribbon Tweeter
The Dayton Audio PT2C-8 features a large diaphragm, providing greater power. The membrane is thermally attached to an aluminum plate, dramatically increasing the dynamic range.
Reference : 3683
85,00 €tax incl.
70,83 € tax excl.
Shipping date: 25-04-2024.
Shipping from France
Billing in France
Technical support in France
Many audiophiles are impressed by the qualities of ribbon tweeters for their clarity, transparency and the quality of the sound imgae. The key to their performance is the tape, which is almost weightless.
It consists of a Kapton film and aluminium conductors, which are placed between two rows of magnets. The result is an immediate and precise response to any transient in the original signal and the ability to deliver detailed music.
The flared waveguide produces a horizontal dispersion which allows an excellent off-axis response. It also limits vertical dispersion and reduces floor and ceiling reflections.
Perfect for Line Array. A second order filter is recommended with a cutoff frequency of 3 kHz or higher.
The frequency can be lowered to 2500Hz with a third order filter.
Specifications:
  • Power: 80W RMS / 115W max
  • Impedance rating: 8 Ohm
  • DC resistor: 7.6 ohms
  • Ribbon size: 120mm x 27mm
  • Frequency: 2000-26000 Hz
  • SPL: 94 dB at 1 W / 1m
  • Dimensions: Overall Diameter: 6-5/8 "x 3-1/2" / Cutting Diameter: 2-5/8 "x 6-3/16".
  • Mounting depth: 7 / 8"
Dimensions PT2C-8 Dayton Audio
Réponse en fréquence PT2C-8 Dayton Audio
Speaker Power (W RMS)80.0
Speaker TypeRibbon tweeter
Impedance (Ω)8
Loudspeaker diameter (mm)120.0
Diaphragm typeMylar
Efficiency / Sensitivity (dB)94.0
Max Linear Excursion (Xmax) (mm)N/A
Lowest frequency (Hz)2000
Highest frequency (Hz)26000
The Dayton Audio PT2C-8 features a large diaphragm, providing greater power. The membrane is thermally attached to an aluminum plate, dramatically...
