DAYTON AUDIO RS100-8 Reference Speaker Driver Full Range Aluminium 30W 8 Ohm 85dB 90Hz - 20kHz Ø10cm
Dayton Audio RS100-8 Reference Haut Parleur Large Bande 10cm
Range"Reference Series"DAYTON AUDIO redefined the concept of value for money in the highly competitive ultra-high performance speaker market. Combining a sophisticated engine with internal 2 distinct electrical shortcuts, andacone in ultra rigid aluminum, the transducers of this series dethrone from their pedestal many more expensive realizations.
4.5 / 5
Reference : 6481
45,90 €tax incl.
38,25 € tax excl.
Shipping date: 02-04-2024.
Shipping from France
Billing in France
Technical support in France
The objective here is tomaintain extremely low distortion rates, and this in spite of a holding in comfortable powerand anparticularly wide frequency response .
Successful bet if judging by the quality of listening and exceptional versatility of the unit RS100-8.
And to spoil nothing, this loudspeaker adopts a look of the most attractive with its cone of black anodized color , herlarge suspension half rubber rollerhigh quality, sound Ultra rigid proprietary chassis and perfectly ventilated, and its connection plated Gold 24k.
Features:/ Strong>
  • Multi-Purpose SpeakerWide Band
  • Largely ventilated motor eliminating compression phenomena that are harmful to the linearity and silence of the excursion
  • Conevery resistant in Aluminum Anodized Black
  • Dual-track electric motor for minimum distortion
  • High quality building materials for increased durability
  • terminalsGold plated 24k
DAYTON AUDIO RS100-8 Reference Large
Speaker Power (W RMS)30
Speaker TypeFull range
Impedance (Ω)8
Loudspeaker diameter (mm)100.0
Diaphragm typeAluminium
Efficiency / Sensitivity (dB)85.0
Max Linear Excursion (Xmax) (mm)12.0
Lowest frequency (Hz)90
Highest frequency (Hz)20000
6 reviews
Excellent quality. Extremely clear sound, but poor in low frequencies due to its size. Excellent choice!
This review has been posted for DAYTON AUDIO RS100-8 Reference Speaker Driver Full Range Aluminium 30W 8 Ohm 85dB 90Hz - 20kHz Ø10cm
Excellent quality.
Bon HP large bande à prix démocratique
Donne de bons résultats monté dans une enceinte de 5 litres accordée à 60 Hz pour un usage de monitoring en MAO et d'écoute de proximité. Au début les aigües étaient un peu timides, défaut disparu après quelques heures d'utilisation (rodage ?). Ecoute très "analytique" et neutre, c'était le but visé, mais les graves sont tout de même bien présents malgré la petite taille des enceintes.
A utiliser avec un filtre
J'ai utilisé ce large bande pour rénover une vielle radio.
Je suis assez déçu du produit. Le médium est plus que présent. Vie haut parleur nécessite un filtre
J'ai du le remplacer.
Si une bonne âme peut me conseiller sur les valeur a utiliser pour créer un filtre je suis preneur.
Le résultat médiocre peut être lié à la source et à l'amplification utilisée.
Dans l'absolu un large bande d'entrée de gamme ne peut donner (même bien traité) un résultat hifi.
Testé également à 250Hz dans la même configuration
Avec une fréquence de coupure à 250Hz dans un volume d'enceinte de 4 litres la distorsion reste en dessous des 0.5%.
A noter qu'avec 96dB maximum admissible à 1.00m, le son peut devenir brouillon sur de la musique orchestrale dans un fortissimo.
Pourtant, le calcul du déplacement de cône donnant 1.5mm maximum, on est qu'a 33% du Xmax. Avec un signal complexe, cela peut également provenir de l'ampli de 50W RMS utilisé.
Range"Reference Series"DAYTON AUDIO redefined the concept of value for money in the highly competitive ultra-high performance speaker...
