DAYTON AUDIO UM18-22 Ultimax DVC Speaker Driver Subwoofer 1000W 2x2 Ohm 87dB 19Hz - 500Hz Ø46cm
DAYTON AUDIO UM18-22 Ultimax DVC Subwoofer Speaker 2+2 Ohm Ø46cm (Unit)
Dayton Audio's Ultimax series DVC subwoofers are specially designed to move energy and create clean, articulate, tense fast bass. Discover the best price-to-market ratio!
Strengths:
  • Power consumption 1000 w on 4 ohm. (2 coils)
  • Resonance frequency 19.5Hz.
  • As efficient in Hifi use as Home Cinema.
  • Nomex cone low colouring
By buying this product you get 48 loyalty points
Reference : 12582
489,00 €tax incl.
407,50 € tax excl.
Shipping date: 29-03-2024.
Shipping from France
Billing in France
Technical support in France
Ultimax
Subwoofer DVC 4Ω ⌀44cm 1000W RMS
This exceptional subwoofer with ultra rigid aerial chassis has powerful ceramic magnets. Its Nomex/glass fiber cone with high stiffness in honeycomb structure produces powerful bass, defined without harmful coloring. Thanks to its 2+2 coils system and its long linear elongation, this subwoofer is able to reach frequencies of 19.5Hz.
Alignment possible according to pure volume and load :
  • Closed volume: (home theater/music): 113 L for 27 Hz f3 alignment, or f10.18 Hz with Qtc of 0.7
  • Closed volume (music): 7 cubic feet (internal net, unmanned) for a 26 Hz f3,15.8 Hz f10 with a Qtc of 0.76
  • Bass reflex (home cinema): 227 liters at 20 Hz, with 3 flared vents of 10cm diameter and 71cm long, for an f3 of 18 Hz.
  • Bass Reflex (infra-sub): 340 Litres, with 3 flared vents of 10 in diameter and 81 in length, for a f3 of 15 Hz.
  • For all these volumes he adds that of the Huat loudspeaker and vents in the calculation.
Technical caractheristics
Type de haut parleurSubwoofer
Diamètre nominal42cm (18")
Matériau membraneNomex Glass fiber
Matériau aimantceramic ferrite
Total diameter442mm
Depth259mm
powerRMS : 1000W on 4 ohm  2+2 coils
MAX : 2000W
Impedance
Sensibility88.6dB @ 2.83V/1m
frequency response19.5Hz - 500Hz
Resistance DC (Re)4.4Ω
Inductance coil (Le)2.22mH @ 1kHz
Resonance frequency (Fs)19.5Hz
 (Qms)3.82
 (Qes)0.62
(Qts)0.53
Air load (Mms)655g
 (Cms)0.1 mm/N
Emmissive aera (Sd)1,219cm²
Air volume (Vd)2,681.8 cm3
Linear maximum exurcion (Xmax)22mm
Optimum cabinet size according to BassBox 6 Pro
Sealed Volume119.50 Litres
Sealed F331 Hz
Vented Volume333.86 Litres
Vented F316 Hz
Speaker Power (W RMS)1000.0
Speaker TypeSubwoofer
Impedance (Ω)4
Loudspeaker diameter (mm)460.0
Diaphragm typeGlass fiber
Diaphragm typeComposite alloy
Efficiency / Sensitivity (dB)88.0
Max Linear Excursion (Xmax) (mm)22.0
Lowest frequency (Hz)19
Highest frequency (Hz)500
Dayton Audio's Ultimax series DVC subwoofers are specially designed to move energy and create clean, articulate, tense fast bass. Discover the...
