BLUESOUND NODE 2 Hi-Fi Streamer 24bits/192KHz Black
The BlueSound Node 2 is a high-definition multi-room network player that will allow you to enjoy your music without limits throughout your home.
  • 24bits 192kHz
  • DAC TI5122
  • ARM Cortex 9 1Ghz Processor
  • Multiroom
  • Bluetooth 4.0 aptX
By buying this product you get 54 loyalty points
549,00 €tax incl.
457,50 € tax excl.
Shipping date: 19-03-2018.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
Bluesound Node 2
Bluesound Node 2 Black
Network reader 24bit 192kHz streamer multiroom
The NODE 2 is a 32-bit streamer multiroom reader wireless Hifi. It allows playback of your 24 bit 192Khz HD files with an audiophile sound, with a wide digital connection and Bluetooth APTX.
ARM Cortex A9
NODE 2 will give you access to Spotify, Deezer as well as the main streaming services and Internet radios.
Thanks to its numerous outputs, you can connect it to a wide range of digital and analog products, the NODE 2 will instantly give a second life to your equipment, even to the most vintage ones.
The Streamer Node 2 with its 32 bit Ti 5122 DAC seamlessly decodes HD files (lossless) at high sampling frequency (192KHZ). The very high computing power of the ARM Cortex 9 1 GHz multi-core processor brings a level of reactive user comfort without slowing down for the control and the diffusion of the music in streaming in all your rooms.
Distribute all your music in all the rooms of the house Multiroom
A high quality audio environment.
The NODE 2, like all Bluesound drives, is controlled from your smartphone or tablet with a free IOS or Android application.
The control interface gathers all your sources, on Cloud, on your computer, your smartphone, a NAS or almost all other sources via the inputsanalog and digital. Streamer from Wi-Fi or from Bluetooth, or connect it to your Ethernet LAN.
Whatever the source, Bluesound will be your companion High fidelity high resolution available until the resolution Studio Master 24/192.
Qobuzissime-300x121.jpgArrière bluesound node 2
Video test in English
Control your HiFi system from your smartphone or tablet
You can browse your music collections from the Bluesound app on your smartphone, tablet or computer. The free Bluesound app is available under iOS and Android.
application bluesound
bluesound node 2
ProcessorARM Cortex TM - A9 1GHz
Supported file formats MP3, AAC, WMA, OGG, WMA-L, FLAC, ALAC, WAV, AIFF
Native sampling rate32 - 192kHz
bit16 - 24
Compatible operating systems Windows Vista 7, 8, Apple Macintosh OS X 7-10
DAC32bit 192kHz
Signal to noise ratio-110dBa
THD + N0.005%
OrdersLED Tactiles
FoodUniversal AC power cord with two pins (100-240 AC)
Connectivity / Connectivity
Ethernet RJ45 GigE
WIRELESS802.11 b / g / n
Bluetooth4.0 aptX
IR OpticsIn front + IR remote input (3.5mm jack)
1x USB-A / 1x USB-B (for product support)
ExitsRCA Stereo / Coaxial / Optical Toslink / Headphone Jack 3.5mm / Subwoofer RCA / Trigger 12V
Dimensions220 x 46 x 146mm
Included AccessoriesMains cable 120V AC / Mains cable 230V AC / Ethernet cable / RCA cable Stereo to RCA / Cable 3.5mm Stereo mini to RCA / Mini Toslink optical adapter to 3.5mm / Warranty certificate / Installation guide
Colissimo - TNT - SoColissimo
The BlueSound Node 2 is a high-definition multi-room network player that will allow you to enjoy your music without limits throughout your home....
