PACK DAVIS ACOUSTICS MIA 20 Bookshelf Speakers + FX-AUDIO D302 PRO FDA Amplifier
PACK DAVIS ACOUSTICS MIA 20 Bookshelf Speakers + FX-AUDIO D302 PRO FDA Amplifier New
This package consists of a pair of Davis Acoustics MIA 20 two-way bookshelf speakers and an FDA FX-Audio D302 Pro amplifier. It thus constitutes an almost complete audio system at a low price but still powerful. An ideal set to enjoy a quality reproduction, especially in a small / medium room.
Reference : 13996
182,50 €tax excl.
Instead of 190,75 €
Including 0,04 € for green tax
Pack content
  • 49,92 € 49,92 €VAT
    In Stock
  • 1 x
    In Stock
    The smaller Davis Acoustics model, the MIA 20s benefit from advanced technological solutions that can be found in higher range models. These small 2-way bookshelf speakers are equipped with a 13cm fiberglass boomer/midrange offering a good transient regime while ensuring low mechanical deformation.
    140,83 € 140,83 €VAT
    In Stock
Pack Davis Acoustics MIA 20 + FX-Audio D302 Pro
Speaker Bookshelf 2 Way + FDA Amplifier 2x30W
Pack Enceintes Bibliothèques Davis Acoustics MIA 20 + Amplificateur FDA FX-Audio D302 Pro
Davis Acoustics MIA 20 Bookshelf Speaker
Smaller model from Davis Acoustics, the MIA 20s benefit from advanced technological solutions that can be found in higher range models. These small 2-way bookshelf speakers are equipped with a 13cm fiberglass driver/midrange driver offering good transient performance while ensuring low mechanical deformation, as well as a 25mm soft dome tweeter made of coated fabric. In addition, the speaker body contains a high quality crossover filter, providing linear listening for long hours of listening without listening fatigue while providing accurate playback. A Bass Reflex system with a large front vent allows you to deliver deep bass. The frontal positioning of these vents allows the MIA 20 to be placed directly against a wall. The 88dB efficiency of these speakers allows them to be associated with all amplifiers on the market.
At the rear, the speaker offers screw terminals that accept banana plugs, but also a system that allows the speakers to be simply positioned against a wall.
Test des Davis Acoustics MIA 20 par On-Mag
" Listening, the Davis Mia 20 are real HiFi speakers that have a lot of charm. For the price at which they are offered, there is not much to complain about. We know of many more expensive ones that sound much worse. "
FX-Audio D302 Pro FDA Amplifier
This FX-Audio D302 Pro amplifier is based on a STA369 amplification chip allowing it to deliver a power of 2x30W under 8Ω while taking advantage of the high efficiency allowed by its Class D architecture. The D302 Pro has the particularity of being a Full Digital, i.e. the S/PDIF or USB signal is converted into I2S by an AK4113 chip then directly amplified. This technology reduces the number of digital processes to just three steps rather than five or six on a more traditional system.
On the connector side, there is a USB-B OTG compatible with many smartphones, a Coaxial S/PDIF and a Toslink Optics, but also, more rarely for an FDA, an analog RCA input. These inputs are supported by an AKM AK4113 S/PDIF AKM interface and a CM108 USB interface, supporting PCM sampling rates up to 24bit 192kHz. The analog input is associated with an ADC PCM1808
Finally, the D302 Pro is designed to be easy to use. Its front panel includes the necessary buttons for source selection, volume adjustment and switching the unit on/off.
Davis Acoustics MIA 20 Specifications
Product typeSpeakers
Speaker formatBookshelf speaker
PowerNominal: 80W RMS
Max: 110W
Number of way2
Speaker driver number2
Efficiency88dB
Frequency response55Hz - 20kHz
Tweeter25mm, dôme souple
Medium / Woofer13cm, fiberglass
ImpedanceMin. 5Ω
Cutout frequency3000Hz
Bass ReflexFront laminar air vent
Binding post typeScrew binding posts, accept banana plugs
FinishBlack wood
FX-Audio D302 Pro Specifications
Product typeFDA Amplifier
Amplifier chipSTA369
Amplifier power2x30W @ 8Ω
Amplification typeClass D
ADC PCM1808
Headphone amplifierNE5532
S/PDIF InterfaceAKM AK4113
USB InterfaceCM108
SNR100dB
Distortion0.06%
EqualizationBass, treble
Inputs1x Coaxial S/PDIF
1x Optical Toslink
1x USB-B
1x Stereo RCA
Outputs1x Speaker Binding Posts
1x Jack 3.5mm
Voltage supply15V 4A on Jack 5.5/2.1mm (included power supply)
Weight700g
Pack content1x Pair of Davis Acoustics MIA 20 speakers
1x FX-Audio D302 Pro Amplifier
InputUSB-B
InputUSB 2.0
OutputJack 3.5mm
OutputSpeaker terminal
Max sampling rate192kHz
Channel2 channels (Stereo)
amplifier chipSTA369
Power (max)30W
Colissimo - TNT - SoColissimo
This package consists of a pair of Davis Acoustics MIA 20 two-way bookshelf speakers and an FDA FX-Audio D302 Pro amplifier. It thus constitutes an...
