Pack FX-AUDIO D802C PRO FDA / Q ACOUSTICS 3010i / OFC speakers Wires 2m
Pack FX-AUDIO D802C FDA / Q ACOUSTICS 3010 / OFC speakers Wires 2m
By buying this product you get 39 loyalty points
Reference : 11052
399,00 €tax incl.
332,50 € tax excl.
Instead of 432,90 €
Shipping from France
Billing in France
Technical support in France
Pack content
This pack consisting of an amplifier FX-AUDIO D802C PRO Black and a pair of speakers Q Acouctics 3010i fintion Graphite Blackwill be perfect for a mini HIFI channel with a big sound.
This pack is also composed of of a pair of enclosure cables OFC copperwith banana plugs, a length of 2 meters with red sheath of the most beautiful effect.
Thus you have a high fidelity channel in a compact format with the sound of English productions bringing warmth, dynamics, melodic meaning typical of this type of realization.
The 3010i has many new aspects, both internal and external. The new tweeter and drive motor allow the new 3010 enclosure to deliver exceptional performance especially at the bottom of the spectrum. This pair of speakers redefines sound performance standards in its class.
The FDA amplifier FX AUDIO D802C PRO has all the necessary embedded technology. With its VIA VT1630A DSP its capabilities Wireless Bluetooth 4.2 and its USB 2.0 audio port, it will be able to transcribe the least musical information of your computer or other digital apparatus with more than 2x50W 8 Ohm.
An excellent compromise between High Definition and compactness that will bring great musical satisfaction to music lovers not wanting to sacrifice place and esthetprices.
Pack content:
  • 1 pair of Speakers Q Acoustics 3010i Graphite Black
  • 1 Amplifier FX AUDIO D802C PRO USB 2.0 Bluetooth 3.0 OLED display
  • 1x Pair of cables HP OFC bananas 2m with protective sleeve red
FX-Audio Specifications:
  • S & PDIF Interface AKM AK4113
  • Audio Controller / DSP VIA VT 1630A
  • ADC Wolfson WM8782S (24bit 192kHz)
  • OLED Screen
  • Displaying sampling rate
  • Wireless reception via Bluetooth 4.2
  • STA326 amplifier module: 2 x 80W at 4 Ohm, 2x 50W at 8 Ohm
  • Filter Capacitors Nichicon 5400μF x3, WIMA x2
  • High-precision clock
  • Signal to Noise Ratio (SNR): 84dB
  • Frequency Response: 18Hz - 22kHz
  • Digital Equalizer
  • Supplied remote control or rotary encoder
  • Inputs: S / PDIF Optical Toslink, Coaxial and USB-B), stereo analog RCA
  • Outputs HP: On screwed terminal blocks supporting the banana plugs 4mm
  • Supplied 32V 5A Power Supply
  • Dimensions: 190x115x39mm
  • Weight: 700 g
  • USB-A to USB-B cable, remote control, 5dB Bluetooth antenna and power supply
Specifications Q Acoustics 3010i :
  • Enclosure Type: 2-way SLR
  • Woofer: 100mm
  • Heavy-duty motor: 22mm
  • Frequency Response: 65Hz - 30kHz
  • Nominal impedance: 6 ohm
  • Minimum impedance: 4 ohm
  • Sensitivity: 86 dB
  • Recommended power: 15 - 75w
  • Transition Frequency: 2.6 kHz
  • Dimensions H / W / W mm: 150x253x252mm
  • Weight: 4.1kg per speaker
  • 5 Year Warranty
ColorGray
