Pack FX-AUDIO D802C FDA / Q ACOUSTICS 3010 / OFC speakers Wires 2m
This pack consisting of an amplifier Full Digital SMSL AD18and a pair of loudspeakersQ Acouctics 3010 fintion Graphite Black will be perfect for a HIFI channel in mini format with a great sound.
By buying this product you get 35 loyalty points
12348
359,00 €tax incl.
299,17 € tax excl.
Instead of 377,90 €
Available
Pack content
  • 219,00 € 182,50 €VAT
    In Stock
  • 29,90 € 24,92 €VAT
    In Stock
  • 1 x
    In Stock
    The SMSL AD18 V3 is the FDA Full Digital Amplifier par excellence. Providing high-definition melodic sound from both Bluetooth 4.2 and 242kHz USB 24bit, it also has a subwoofer active subwoofer output that delivers unbeatable stereo audio for even speakers.
    129,00 € 107,50 €VAT
    In Stock
Accessories
This pack consisting of an amplifier Full Digital SMSL AD18 V3 and a pair of loudspeakersQ Acouctics 3010 fintion Graphite Blackwill be perfect for a mini HIFI channel with a big sound.
This pack is also composed of of a pair of enclosure cables OFC copperwith banana plugs, a length of 2 meters with red sheath of the most beautiful effect.
Thus you have a high fidelity channel in a compact format with the sound of English productions bringing warmth, dynamics, melodic meaning typical of this type of realization.
The3010has many new aspects, both internal and external. The new tweeter and drive motor allow the new 3010 enclosure to deliver exceptional performance especially at the bottom of the spectrum. This pair of speakers redefines sound performance standards in its class.
The FDA amplifierSMSL AD18, rewarded Qobuzissime by Qobuz, has all the necessary embedded technology. With its interface SPDIF CS8422,its capabilities Wireless Bluetooth 4.2 NFC and its output Subwoofer,it will be able to transcribe the least musical information of your computer or other digital apparatus with more than 2x60W under 8 Ohm.
An excellent compromise between High Definition and compactness that will bring great musical satisfaction to music loverswanting to sacrifice place and inner aesthetics at content prices.
Pack content:
  • 1 pair of SpeakersQ Acoustics 3010 Graphite Black
  • 1 AmplifierSMSL AD18 V3 TAS5342A Bluetooth NFC
  • 1x Pair of cables HP OFC bananas 2m with protective sleeve red
Features SMSL AD18 V3:
  • SPDIF Interface: CS8422
  • Interface USB: VT1620A (16bit 44.1kHZ-192kHZ, 24 bit 44.1kHZ-96kHZ)
  • Color display TFT 1.44
  • Bluetooth Interface 4.2 NFC: CSR A64215 A11u
  • FDA Controller: TAS5508C
  • Amplifier Module TAS5342A: 2 x 80W under 4 Ohm, 2x 65W at 8 Ohm
  • Headphone amplifier chip: MAX97220A
  • Double Op-Amp NE5532
  • Total harmonic distortion: 0.04%
  • Frequency Response: 18Hz - 22kHz
  • Digital equalizer with 7 positions (correction +/- 8dB)
  • Color display
  • Digital Inputs: S / PDIF Optical Toslink, Mini Optical Coaxial and Micro USB-B
  • Analog inputs: One input on 3.5mm stereo jack
  • Input on DC jack: Power supply 24V 6.67A
  • Wireless Input Bluetooth BT4.2 Signal Noise Ratio 90DB
  • Outputs HP: On screwed terminal blocks supporting banana plugs 2.5mm
  • Subwoofer output (SW): on 3.5mm jack port "COAX / OPTI1"
  • Headphone outputs: on 32Ohm 53mW @ THD = 0.04%
Q Acoustics 3010 :
  • Enclosure Type: 2-way SLR
  • Woofer: 100mm
  • Heavy-duty motor: 25mm
  • Frequency Response: 68Hz - 22kHz
  • Nominal impedance: 6 ohm
  • Minimum impedance: 6 ohm
  • Sensitivity: 86 dB
  • Recommended power: 15 - 75w
  • Transition Frequency: 2.8 kHz
  • Dimensions H / W / W mm: 235 x 200 x 150
  • Weight: 3.6kg per speaker
  • 5 Year Warranty
[Img-25951-left-large_default_2x]
[Img-25956-left-large_default_2x]
[Img-25954-left-large_default_2x]
Colissimo - TNT - SoColissimo
This pack consisting of an amplifier Full Digital SMSL AD18 and a pair of loudspeakers Q Acouctics 3010 fintion Graphite Black will be perfect for...
