SHANLING TEMPO eC1B Audio CD Player and USB Flash Drive File Reader Silver
SHANLING TEMPO eC1B CD Player and USB Flash Drive File Reader Silver
The Shanling Tempo eC1B CD player is based on a PCM1796 decoding chip and two NE5532P operational amplifiers, providing a rich musicality.
4.6 / 5
Reference : 13459
219,00 €tax incl.
182,50 € tax excl.
Shipping from France
Billing in France
Technical support in France
Shanling Tempo eC1B
Shanling Tempo eC1B Lecteur CD et de Fichiers sur Clé USB Argent
The Shanling Tempo eC1B CD player is based on a PCM1796 decoding chip and two NE5532P operational amplifiers, providing a rich musicality. The AOPs are mounted on a DIP8 bracket. The CD player features an extremely reliable Sanyo HD850 mechanism, ensuring flawless track tracking. The eCB1 Tempo also allows you to read dematerialized files stored on a USB stick or hard disk, thanks to its USB-A port on the front panel. It can also be used as a drive thanks to its Coaxial SPDIF output.
DiagramShanling Tempo eC1B Lecteur CD et de Fichiers sur Clé USB Argent
1Power ON/OFF LED
2Power ON/OFF button
3CD player tray
4Display
5IR receiver
6Multi-directionnal button
7USB-A Input
1Stereo RCA Output
2SPDIF Coaxial Output
3AC Power supply input
Product typeCD Player
Inputs1x CD
1x USB-A
Outputs1x Stereo RCA
1x Coaxial SPDIF
Conversion chipPCM1796
AOP2x NE5532P
CD MechanicSanyo HD850
Line output level2V
Dynamic range96dB
SNR105dB
THD< 0.002% (1kHz)
Crosstalk> 96dB
Supported dematerialized filesWAV, AAC, WMA, MP3
Sampling rate16bit 44kHz
Consumption< 20W
Dimensions216 x 312 x 71mm
Weight3kg
Power supply250V AC (cable included)
ColorSilver and Black
Package1x Shanling Tempo eCB1
1x IR Remote control (CR2032 battery included)
1x Power cable
OutputCoaxial SPDIF
DAC / ADC ChipPCM1796
ColorSilver
5 reviews
Good looking cd player with small fotprint
Perfect. Exactly what I was looking. A small cd player with digital out (the internal dac sounded good too). A bargain.
This review has been posted for SHANLING TEMPO eC1B Audio CD Player and USB Flash Drive File Reader Silver
Superbe platine cd
Déjà très belle finition, mécanique silencieuse
Après quelques heures de rodage,très très bien ce petit lecteur cd
Transparent,vif,que du bonheur
J'ai essayer la sortie numérique avec mon micromega mydac,eh ben c'est moins bien à ma grande surprise !!
Bref a recommander sans réserve si vous avez une belle collection de cd
Bel objet
Bien plus gros que je ne pensais sur la photo (en profondeur). Le joystick de commande est très pratique et efficace. La télécommande moyenne. le son très bon.
excellent lecteur
j'ai comparé ce lecteur à un ensemble lecteur + dac 20 fois plus onéreux mais plus ancien et force de constater que le gap
n'est pas énorme : le tempo a une qualité rare de rendre jusqu'a l'infra grave bien défini et de ne mettre aucune partie du spectre sonore en avant (du coup j'ai réalisé que le manque de grave ne venait pas des enceintes) et que certain dac externe priorise le medium sur le reste
TRES BON PRODUIT...
TRES BON PRODUIT...
Ce petit lecteur, très abordable, impressionne par sa musicalité, sans rapport avec son prix modeste. La qualité de fabrication semble, au moins en apparence, au dessus de tout reproche. Les différents éléments sont assemblés avec précision, la mécanique de lecture d'origine Sanyo est d'une discrétion exemplaire. Certains apprécieront l'entrée USB permettant de lire la plupart des formats audio actuels; on note toutefois une restitution plus sommaire en USB par rapport au même fichier joué en lecture laser (CD). La présence d'un joystick regroupant la plupart des commandes se révèle très pratique. L'usage de la télécommande reste tout de même incontournable pour d'autres réglages (volume de sortie, avance/retour rapide dans la plage). Sur un plan strictement musical, ce petit tempo est une belle surprise. L'équilibre spectral est sans défaut, aucun registre n'étant mis en avant. Les timbres, d'une fidélité exemplaire, sont servis par une définition sans faille permettant de tout entendre sans accentuation ni brillance artificielle. La fluidité, le côté liquide de la musique est très bien respecté. L'image stéréo est stable et précise, tout au plus aurait on souhaité une image un peu plus profonde, cette remarque se situant à un haut degré d'exigence. Enfin la dynamique est toujours en situation, en particulier dans la restitution des nuances fines. Rapport qualité/prix: 10/10. reste une inconnue: la fiabilité !...
