Gros problème de souffle. Audiophonics a repris ce produit sans problème mais n'a pas réussi à le remplacer par un modèle ne présentant pas ce défaut. Je suis étonné que ce produit soit encore en vente sur le site.
Class D Amplifier 2x100W 6 Ohms
Wondom, a subsidiary of the renowned electronics manufacturer Sure, offers with its A2100 amplifier a versatile system capable of delivering 2x100W under 6 Ohms, with excellent efficiency.
If it is so effective, it is also its great versatility. In fact, it integrates both a Micro USB input, a stereo RCA input, an Optical SPDIF input and a 3.5mm jack input (on the front panel), and will also allow you to play your music directly from your sofa via Bluetooth. It will also be ideal for headphone listening, with its 3.5mm jack output on the front panel.
In addition, if necessary, you can connect a subwoofer for a bass boost, whose level is adjustable directly at the rear of the amplifier.
Wondom offers an infrared remote control for remote control of the A2100. This will allow you to turn the amplifier on/off, adjust the volume, change channels and sources. A real gain in terms of user comfort.
" Compact, powerful and offering more than good sound performance, with two analog inputs, an optical digital input and a Bluetooth link, the Sure Explorer A2100 amplifier can form the heart of a Hi-Fi system that combines the modernity of Bluetooth transmission with a certain tradition of other sources that can be connected to it. "
Connectors : Inputs | |
RCA Stereo | 1x |
SPDIF Optical | 1x |
Micro USB | 1x |
Jack 3.5mm | 1x |
Bluetooth | Class 2 |
Connectors : Outputs | |
RCA for Subwoofer | 1x |
Jack 3.5mm | 1x |
Speakers output | - |
Output power | 2x100W 6 Ohms |
Type | Class D |
Efficiency | > 90% |
Input sensitivity | At 6Ω 100W 1kHz, Jack 3.5mm : 294mV At 6Ω 100W 1kHz, RCA : 496mV |
Sampling rate | Up to 96kHz |
Frequency response | 20Hz - 20kHz |
THD | At 6Ω 100W 1kHz Jack 3.5mm : 0.05% At 6Ω 100W 1kHz RCA : 0.042% |
Output noise | 620uV |
SNR | 82W at 6Ω THD+N 1% RCA : 82dB |
Protections | Over/undervoltage Overcurrent Temperature |
Power Supply | Jack 5.5/2.5 DC 12V at 36V |
Dimensions | 21 x 12.5 x 4.8cm |
Power supply | 24V 5A (not included) |
Accessories | IR Remote Control |
The volume knob also allows you to change the source by pressing and turning the source.
Input | Jack 3.5mm |
Input | Bluetooth |
Input | RCA |
Input | Optical |
Output | Speaker terminal |
Output | Subwoofer |
Output | Jack 3.5mm |
Color | Black |
Channel | 2 (Stereo) |
Class | Class D / T |
Power (W) | 100.0 |
Average votes 2.8 / 5 5 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Michel S.
Niccolò P.
Jérôme L.
Alex I.
Stephane C.
