FOUNTEK NEO CD3.0 Speaker Driver Ribbon Tweeter 17W 7 Ohm 95dB 1400Hz - 40kHz Ø6cm
FOUNTEK Neo CD3.0 Black Tweeter à ruban 60 mm
Reference : 2866
115,00 €tax incl.
95,83 € tax excl.
Shipping date: 25-04-2024.
Shipping from France
Billing in France
Technical support in France
The Fountek Neo CD3.0 ribbon tweeter has the advantages of this technology:
  • Flat frequency response
  • High Quality Harmonics
  • Transition, impulse response faster than a conventional tweeter
  • Low resonance at 400hz
  • Yield of 95dB
The Fountek ribbon tweeters are equipped with a low induction impedance transformer allowing the ribbon to adapt perfectly to the amplifiers on the market.
Here is an excellent choice competing with the best dome tweeters from the market for a lower price.
The series Neo-Fountekhas a thick ribbon (0.02mm) and can be used with a 12dB / oct filter.
  • Ribbon Weight: 18mg
  • Ribbon dimensions: 8x60x0.02mm
  • Ribbon surface: 480mm²
  • Impedance: 7 Ohm
  • DCR: 0.02 ohm
  • Sensitivity: 95dB / M / W
  • Frequency response: 1400 ~ 40000Hz
  • Resonant Frequency: 400Hz
  • Power: 17W, 40W Max
  • Weight: 650g
Warning !Ribbon tweeters with transformers require a high-pass fitting of the direct current to avoid any damage with the amplifiers.
Speaker Power (W RMS)17.0
Speaker TypeRibbon tweeter
Impedance (Ω)7
Loudspeaker diameter (mm)60.0
Diaphragm typeAluminium
Efficiency / Sensitivity (dB)95.0
Max Linear Excursion (Xmax) (mm)N/A
Lowest frequency (Hz)1400
Highest frequency (Hz)40000
Excellent tweeter
Bonjour,
Je suis ravis du résultat des NEO CD 3.0, pour tout vous dire le rendement est supérieure au tweeters que j'ai sur mes colonnes B&W 683 s1, bien sur j'ai aussi créer mes filtre passe haut à 3500 hz avec les éléments de chez AUDIOPHONICS .
La livraison rapide et super bien emballez.
j’espère que mon prochain achat sera aussi nickel.
Davide LI PUMA
This review has been posted for FOUNTEK NEO CD3.0 Speaker Driver Ribbon Tweeter 17W 7 Ohm 95dB 1400Hz - 40kHz Ø6cm
