FOUNTEK NEO X2.0 Speaker Driver Ribbon Tweeter 25W 8 Ohm 94dB 1200Hz - 40kHz 12 x 60mm
FOUNTEK Neo X2.0 Tweeter à ruban
These tweeters are of the highest quality, with damping under the front panel, neodymium magnets, high efficiency and linear frequency response. Fountek ribbon tweeters feature a transformer to enable the ribbon, which has only 0.02 Ohm of original impedance, to be connected to an amplifier with the correct impedance. The Fountek-Neo series has a thick ribbon (0.02mm) and can be used with a 12 dB/oct. filter.
Reference : 6805
115,00 €tax incl.
95,83 € tax excl.
Shipping date: 23-04-2024.
Shipping from France
Billing in France
Technical support in France
Fountek is a manufacturer of ribbon tweeters.
These tweeters are of the highest quality, with damping under the faceplate, neodymium magnets, high efficiency and linear frequency response.
Characteristics :
113.5mm x 69mm rectangular faceplate
Fountek’s 3rd generation ribbon driver technology
12mm width enforced sandwich ribbon diaphragm
Higher power handling, lower distortion, very fast transition
Strong Neodymium magnet
Built-in impedance convertor
Sensitivity 94dB/1m/2.83v
Power handling 25W nominal,43W max
Frequency range 1,200-40,000Hz
Nominal impedance 8 ohm
DCR 0.02 ohm
Ribbon dimension 12mmX60mmX0.015mm
Effective ribbon area 720 square millimeter
Ribbon weight 27 milligram
Gap flux 0.4 Telsa average
Gap height 13 millimeter
recommend cut frequency 2,500Hz with 2-order
Net.Weight 750 gram
https://www.audiophonics.fr/images2/6805/6805_FOUNTEKNEOX20_1.jpg
https://www.audiophonics.fr/images2/6805/6805_FOUNTEKNEOX20_2.jpg
https://www.audiophonics.fr/images2/6805/6805_FOUNTEKNEOX20_3.jpg
https://www.audiophonics.fr/images2/6805/6805_FOUNTEKNEOX20_4.jpg
Speaker Power (W RMS)25.0
Speaker TypeRibbon tweeter
Impedance (Ω)8
Loudspeaker diameter (mm)60.0
Diaphragm typeN/A
Efficiency / Sensitivity (dB)94.0
Max Linear Excursion (Xmax) (mm)N/A
Lowest frequency (Hz)1200
Highest frequency (Hz)40000
These tweeters are of the highest quality, with damping under the front panel, neodymium magnets, high efficiency and linear frequency response....
