AUDIOPHONICS LPSU25 Linear Regulated Power Supply EMI RFI Filter 7V 2A 25VA
AUDIOPHONICS Linear Regulated Power Supply EMI RFI Filter 6V 3.5A 25VA
Here is the low noise regulated 7V 2A audiophile power supply for any device running on the iSabre V3 / V4 and its specific regulation.
4.6 / 5
Reference : 11363
75,00 €tax incl.
62,50 € tax excl.
Shipping from France
Billing in France
Technical support in France
Audiophonics Regulated linear power supply
Regulated linear power supply, EMI/RFI Filter 7V 2A 25VA
Alimentation linéaire régulée filtre EMI RFI 6-7V 2A 25VA
Here is the low noise regulated 7V 2A audiophile power supply for any device running on the iSabre V3 / V4 and its specific regulation. Now the Rapstouch touchscreen player with iSabre V3, as well as the Raspdac with iSabre V3 / V4 finally have the regulated and stable linear power supply for any high quality audiophile DIY project. All the necessary technical refinements are incorporated into this dedicated audio power supply. It includes a 34n series Hexfet IRF controller driven by an OP Analog-Device amplifier and not an integrated circuit. The built-in EMI RFI filtering ensures very low electrical pollution noise (-30mv).
The benefits of a linear power supply for our DAC iSabre V3 are a better readability of the high-pitched midrange and a much better detour bass. Thus this regulated linear power supply solution developed for the DAC iSabre V3 competes with much more expensive Streaming solutions. Equipped with a 100% Aluminium housing and two 5.5/2.1mm DC jack outputs, this extremely stable power supply even under heavy load will allow you to get the most out of the connected audio elements.
The power supply is supplied with a 5.5/2.1mm DC jack male/male cable with 75cm ferrites.
This power supply is supplied in 7V. However, it is possible to adjust this voltage to 6V.
compatible devices :
RaspDAC I-Sabre V4 - DIY Kit
RaspDAC I-Sabre V4 - Audiophile streamer
RaspTouch I-Sabre V4 - Tactile Audiophile streamer
Product typeRegulated linear power supply
Input voltageAC 220V
Output Voltage / Current7V 2A (Max continue)
7V 3A (Max 5 min)
Outputs2x Jack DC 5.5/2.1mm
TransformerMolded anti-vibration shielded 25VA
RegulatorIRF HEXFET type, drive by AOP
EMI / RFI FilterWith self and film capacitors
Power supply noiseRipple < 100mV
Housing materialBrushed Anodized Aluminium
Power supplyIEC (Included cable)
Dimensions174 x 100 x 51mm
Weight850g
Package1x Audiophonics linear power supply
1x Jack DC 5.5/2.1mm male/male with ferrites 75cm
InputIEC C14
OutputJack DC 5.5/2.1mm
Output voltage (V)6.0
Output current (A)2.0
Input voltage (V)230.0
Power SupplyLinear
8 reviews
Excellente alimentation linéaire
Acheté en complément d'un raspberry Pi 3+ et d'un AUDIOPHONICS I-SABRE V4 DAC ES9023 TCXO. Aucun bourdonnement à signaler et tensions parfaites.
Je recommande
This review has been posted for AUDIOPHONICS LPSU25 Linear Regulated Power Supply EMI RFI Filter 7V 2A 25VA
Un beau produit
Mon appareil était bien assemblé et a fonctionné parfaitement dès la première mise en marche. Le transformateur toroïdal ne bourdonne pas et la tension de sortie est exempte de bruit et demeure très stable, Seul bémol il n'est pas possible de commuter la tension d'alimentation pour utilisation avec un secteur à 120 Volts. J'ai résolu ce problème avec un transformateur élévateur 120-240 Volts et je suis tout à fait satisfait du résultat.
Bonne alim. souci de finition.
Bonne alimentation, tension très stable.Possibilité de faire ajuster la tension à la commande (7v dans mon cas)..et la tension personnalisée est écrite sur la petite étiquette au dos !
Fonctionnement très silencieux. Chauffe peu, mais non testée sous forte charge.
Boîtier de fabrication robuste avec des matériaux de quallité (alu) mais souci de finition :
Le feeling, et le bruit, de l'interrupteur est très médiocre
pieds en silicone mal collés, non alignés sur mon appareil
Défaut d'alignement assez important de 2mm entre la façade et le corps du boîtier sur un côté de l'appareil. pbl de Tolérances de fabrication ou d'assemblage.
petite led blanche comme témoin de marche: sympathique et tendance...mais pas rationnel pour une alim. Un détail.
Fine product
Arrived as scheduled,last Friday.It works fine as expected.Thanks Audiophonics
Very good product
Arrived as scheduled in very good packaging.I just got it yesterday so I haven't had the time to really test it. I used it once and it seems to be working perfectly. It's a 9volt version, used on a sotm sms200 network player. Overall a very good product.
