AUDIOPHONICS PSU-HC Linear Power Supply for Auralic Aries Le / Aries Mini 16V 4A
AUDIOPHONICS Linear Regulated Power Supply 16V 2.5A 60VA
Reference : 11972
165,83 €tax excl.
alimentation linéaire 12v régulée audiophile HIFIThis regulated linear power supply 16V 4A with two jack outputs on 5.5 / 2.1 & 5.5 / 2.5, is dedicated for HiFi audio devices requiring clean and neat power.
It will bring back background noise, a lowering of the "ripple" harmful to the jitter on digital audio devices such as DAC or high fidelity streamers. The result is an improvement of the readability of the acute medium with a less digital sound, a contribution, a seating of the timbre, and a better dynamic bass.
The components of this power supply are of first quality:
  • Metal Resistors
  • 10 capacitors filtering 2200uF / 35V
  • Voltage Regulator LT1083
Thus, this regulated linear power supply developed by our team comes to compete with more expensive solutions.
Equipped with a 100% Aluminum case, two Jack DC 5.5 / 2.1 & 5.5 / 2.5, this power supply with an extremely stable 100VA transformer even under heavy load, and will allow you to make the best of connected audio components requesting from 16V up to 4A.
Cand feeding cno DC power cable or DC cable. They are available here:
Cable DC Jack to JACK 5.5-2.1mm
DC cable to JACK 5.5 2.5mm
Power cable:
Olflex 110CY 3X2.5mm² shielded electrical cable
Features:
  • Case: 100% Brushed and sanded aluminum
  • Black Anodized
  • Input Voltage: AC 220V
  • Output Voltage / Current: 16V 4A DC
  • 1 output Jack DC 5.5 / 2.1mm
  • 1 DC jack output 5.5 / 2.5mm
  • IEC base with fuse holder
  • Transformer 100VA
Dimensions and weight:
  • 240 x 169 x 50 mm
  • Weight: 2.1kg
  • Mains cable and DC mains plug not included
InputIEC C14
OutputJack DC 5.5/2.5mm
OutputJack DC 5.5/2.1mm
MaterialAluminium
StructureMetal
StructureAluminium
StructureWood
StructureGlass
StructureZinc
Output voltage (V)16.0
Output current (A)4.0
Input voltage (V)230V
Power SupplyLinear
Colissimo - TNT - SoColissimo
2 reviews
Alimentation linéaire audiophonics
Parfaite pour alimenter un Aries mini. Avec cette alimentation, l’Aries mini est un lecteur reseau de très haut niveau, comparable à des produits beaucoup plus coûteux.
Le top pour utiliser Qobuz.
This review has been posted for AUDIOPHONICS PSU-HC Linear Power Supply for Auralic Aries Le / Aries Mini 16V 4A
Apport indéniable
Apporte du poids et du corps aux instruments par rapport à l'alimentation d'origine.
Petit plus que mérite l'aries mini si l'on a un système haute fidélité.
